Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-06-2004, 08:15 PM
65 chero 65 chero is offline
Garage is empty, add now
65 chero is starting off with a positive reputation.
Smile tilt steering column
Has anyone had experience in installing a tilt steering column in a 65 rancehero? If so, what make column did you use? Any helpful hints would really be appreciated.
  #2 (permalink)
Old 09-17-2004, 10:49 AM
rodbender rodbender is offline
rodbender is starting off with a positive reputation.
You might look at what the Mustang guys are doing. I have a 65 and I recall a tilt being put in one. You'll look at a 68 and later box as the 67 and earlier have the long shaft as your Ranchero/Falcon has. This will help you get started. Good Luck
  #3 (permalink)
Old 09-19-2004, 08:33 PM
Roger Carter's Avatar
Roger Carter Roger Carter is offline
Roger Carter is starting off with a positive reputation.
Ditto Rodbender's comments. Did this swap a few times many years ago. Not a nut and bolt, but pretty close. I understand some of the street rod parts suppliers have pieces that work, like Flaming River and Ididit. Hope this helps.
Roger Carter
  #4 (permalink)
Old 09-29-2004, 06:20 PM
Thanks for the info. I have been looking for a mustang column here locally, but not too hard as of yet.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
