77 Shifter..
77 Shifter..
I've got a 1977 Ranchero.
It's an Automatic column shifter.
The shifter is really sloppy. The handle just flops back and fourth. Selecting gears is not a problem. Up and down movement is ok. If you’re not careful with it, it will pop out of park and into reverse and roll away. (I've had to run to catch it before. I steped out for a minute with it in park with the engine running )
I'm about ready to put a different steering wheel on. I'm thinking do them both at the same time.
Would it be easier/cheaper to convert to floor shifter? (I've got air grinder) Would the shifter be a PITA to reach? (I mounted VW Recaro seats higher then usual; as I am used to driving German cars. And I think that the Americans of the era enjoyed sitting low on off center steering wheels with their hands at eye-level if they were on the top of the wheel. Rather then 'wrists on the steering wheel' way.. ) Either that or I'm just too short. )
Do they make tall floor shift levers? The column shifter is close to the steering wheel. The floor would have to be pretty tall to be easy to grasp. (I'm used to ones that are a few inches. This one would have to be about a foot if the rod started right at the tunnel metal.
Anyone make performance (sporty, firm..) column shifters?
I'm going to be going though the motor and tranny at the same time. And have not yet decided manual/auto. I don't know where to find conversion brackets (if needed?) Or how to add the clutch pedal; if I go manual, auto is column is out of the idea. I don’t like the idea of 3 (or 4 as the case may be) on the tree.
How does the cost tend to lean Manual vs. Auto? (no oddball 6 speeds or anything and no clunky truck trannys)
There is a C4 in there now behind a 351M.
I'm leaning toward the same thing. Epically if I can make it go better then high 13s. I remember my Jetta witch did mid 13s spun up quick..
Column of Floor?
How does a column even work? That's got to be lots-o-complex stuff there. Does anyone make rebuild kits? Or new columns?
How much power can a C4 (nothin special) hold up to? (new of cource..)
Column of Floor?
what you might need is the retaining clip for the shifter tube. I think the problem around this time was with tilt steering units. what do you have?
the selector sleeve wears out where the pin goes through for the shifter handles .
mine was real sloppy but no problems falling out of park. so I drilled out the handle with a carbide bit (the handle is hard as wood pecker lips)and put in the next size dia pin. it worked but its getting bad again. looks like I should go with a floor shifter myself. drilling it out again would only weaken the handle. let us know what you do
Well.. The pin you talk about goes though the handle. That's in there good. Well. no. It's a size too big (not my doing) and I smashed it in there with vicegrips..ha ha..
Do they make adapter brackets for a manual tranny for these cars? What trannys can I use on the 'big block' 351/400M? I definitely need and overdrive tranny.
