JBL amp will not work - Ford Truck Enthusiasts Forums
Old 09-06-2004, 06:16 PM
timothyjbrownsr timothyjbrownsr is offline
timothyjbrownsr is starting off with a positive reputation.
I have a 1995 ford explorer with the JBL premium sound system. All aspects of the system work well, 6cd, cassette, radio. However, the amp and subwoofer do not seem to work.
I have checked both fuse panels and they are fine - any idesa before I remove the unit?
Thanks!
Old 09-06-2004, 07:18 PM
fordtruckfan90's Avatar
fordtruckfan90 fordtruckfan90 is offline
fordtruckfan90 is starting off with a positive reputation.
Check power at the amplifier, if power then the sub could possible be blowe, also is there a fusible link? Check it out, good luck!
Old 09-07-2004, 12:01 AM
RomerB2's Avatar
RomerB2 RomerB2 is offline
RomerB2 is gaining momentum as a positive member of FTE.
check out your remote turn on lead, also your grounding on the amp, make sure it's clean of paint and dirt and grime, also check all connections, make sure they're in the right places, i would take out HU make sure cables are all on it and plugged in, RCA's can come undone.. umm.. make sure you're fuses arent blown, some fuses that can seem totally irrelavant can be blown, and cause weird things.. if that fails, totally uninstall and reinstall, takes a while but may be worth it
Anybody using a JBL MS-8 with a stock system? Turbo Dog Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 12 05-20-2015 04:59 PM
no bass 96 explorer jbl w/rear sub 7pointstar Explorer, Sport Trac, Mountaineer & Aviator 0 04-09-2007 01:17 AM
96 explorer xlt stock amp location baumben Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 1 05-01-2004 11:58 AM
Need help replacing subwoofer in 95 explorer w/JBL diglizard Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 12 08-28-2003 11:16 AM
Can I use a sub amp that is different from my original Keng Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 0 06-05-2003 09:46 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
