Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
New! Use your Facebook to securely log into this site, click logo to login
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 09-06-2004, 01:38 PM
Bonofied Suitor Bonofied Suitor is offline
Bonofied Suitor is starting off with a positive reputation.
Question I'd like to wire my portable Sirius to OEM stereo
Does anyone know if there are additional imputs I could use at the back of the OEM premium stereo?
What I am looking for is a way to wire a portable Sirius radio into the amp of the premium AM-FM Cassette/CD unit in a 2004 F250 SD Lariet? The unit that I have transmits over an FM frequency that is tuned in with less than ideal results (high frequency noise). If I'm not mistaken, the unit is supposed to be CD changer ready. My other option is to replace the unit completely with an aftermarket stereo. I haven't had any luck getting the unit to come loose using the release tools.
  #2 (permalink)
Old 09-06-2004, 02:24 PM
Yeti's Avatar
Yeti Yeti is offline
Yeti is starting off with a positive reputation.
Usually stock stereos don't have the Aux RCA in's you would need. I believe the cd changer may be proprietary with a special plug end.
Other than the FM modulator that you are using...I think the only other option is to replace the stock unit.
__________________
O.F.F.O.
  #3 (permalink)
Old 09-06-2004, 02:47 PM
wiingnut's Avatar
wiingnut wiingnut is offline
wiingnut is gaining momentum as a positive member of FTE.
Bonofied,
What kind of sirius unit do you have. I can get a heck of a deal on a plug and play unit to run through my factory unit. I wanna know if it is worth it! or the same unit so I know what to steer away from. Thank you
  #4 (permalink)
Old 09-06-2004, 05:06 PM
RealMenPowerstroke! RealMenPowerstroke! is offline
RealMenPowerstroke! is starting off with a positive reputation.
Well first off if you are getting a lot of high freq noise through your fm modulator, most likely you have a defective signal replicator. That's basically the guts of the FM modulator. Exchange the modulator for another and try it. More over, usually you can select from a couple channels you want to broadcast on, try another channel, you might be picking up interference. Also depending on the condition of your altenator sp??. While you have a new truck, that does not mean you have a properly functioning altenator. Aftermarket products are extremely sensitive to any decibel level. Not to exlcude altenator whine. Does the noise fluxuate with the amount of throttle?? If it does, you are picking up altenator whine. Have the dealer change out your altenator under warranty. The cause of this can be a bad spooling. Also since you don't have the in-dash 6, you most like have ch-changer controls that work with a ford changer plug. Now, there are several companies that offer a harness to allow audio input from that changer plug on your factory radio. If you would like to do some searching yourself, try these companies.. Soundgate, AMI, Excel, and I can't remember some others. Keep us posted, let me know if there is anything else I can do..
Best of Luck,
Corey
  #5 (permalink)
Old 09-06-2004, 07:25 PM
wiingnut's Avatar
another concern I forgot to mention in my earlier thread is I have dual alternators.
  #6 (permalink)
Old 09-10-2004, 10:13 AM
Quote:
Originally Posted by wiingnut
Bonofied,
Mine is the Brix Streamer. The unit snaps into a cradle in the truck and generally works well with the exception of the problem described and for some reason it doesn't get much signal from the satellite in the Las Vegas valley. Once we are out of town the unit works great. It's nice to be able to snap it out and use it at the cabin in the woods.
  #7 (permalink)
Old 09-10-2004, 10:16 AM
Quote:
Best of Luck,
Corey
Thanks Corey,
I'll look into those suppliers. The noise is such high frequency that I doubt Ford would consider it worth covering but just what I would expect from a system that transmits tha signal to my tuner rather than directly to the amplifier. I had the exact same problem on my T-bird when I hooked up a CD changer that worked the same way.
  #8 (permalink)
Old 09-10-2004, 11:51 AM
sy5adm1n sy5adm1n is offline
sy5adm1n is starting off with a positive reputation.
I have the Audiovox Sirius system. Used a PIE adaptor and connected my Sirius up directly to the back of my factory 6-disc system. Works great, no more FM modulator. I click on the cd button twice and it comes up with DJ.
If you go this route, make sure to handle the cd player gently, I have to take mine apart now to unstick the cds.
__________________
http://www.ford-trucks.com/user_gall.../58232.320.240
2002 F-250, PSD CC, Auto 4x4, DPPI exhaust, AFE, Di-Pricol gauges, APC tails, Edge Att/Evo, FTVB, Mag-Hytec, Line of Fire, JAD LEDs, Ricksons, 05 front conversion
  #9 (permalink)
Old 09-10-2004, 03:32 PM
Diesel Cruiser Diesel Cruiser is offline
Diesel Cruiser is starting off with a positive reputation.
sy5, what year truck do you have? This seems to be a problem with the '04 multi disc CD's, not '03 or earlier models. I hope you have a solution, I have the same issue with my XM unit.
__________________
'04 Ex Black, 2 x 4 Limited, 6.0. Born on 12/16-03. Now 174,000 miles. XM, Heliwig bars front and rear.
Light loaded so run D series tires for smooth ride and good handling.
  #10 (permalink)
Old 09-11-2004, 06:09 AM
wiingnut's Avatar
sys5,
Could you please tell me what a PIE adapter is? I'm interested in doing what your saying, but can't figure out what it is for the life of me. Thank you.
  #11 (permalink)
Old 09-11-2004, 12:46 PM
A PIE adapter plugs into the rear of the stock system. Its a plug and play, gives you a left and right RCA input. Then you just plug in your XM/Sirius to it and click on the cd button twice to bring up DJ mode. Here is the place I got mine.
http://www.myradiostore.us/auxadapte...ernal-changer/
Some of the 04s were having problems with it, but I'll have to see if I can remember how they were fixing it.
__________________
  #12 (permalink)
Old 09-12-2004, 10:37 PM
Thanks,
Looking at the link you provided, it looks like a FRDN-AUX is just the ticket. I really appreciate your assistance.
  #13 (permalink)
Old 09-13-2004, 12:35 AM
n6nfg n6nfg is offline
n6nfg is starting off with a positive reputation.
Let us know how this works out if you get one. I also have a 2004 6 disk in-dash that I was hoping to get auxillary input working with.
__________________
-n6nfg
2004 F350 4x4 Lariat CC SB 6.0 Auto, ARP Studs, X3, 4" Exhaust, EGT/Boost gauges
Medium Wedgewood over Silver, moonroof
  #14 (permalink)
Old 09-13-2004, 08:53 AM
Looking at their chart, it stops at the 2003 model Excursions. That is the same trouble I have been having finding an adaptor for my 2004 in-dash; they are different!
__________________
  #15 (permalink)
Old 09-13-2004, 11:02 AM
If you have a 20 pin connector on the back of your 6 disc cd player (the PIE #FRDN-AUX) should work. The 2003 and 2004 players have the 20 pin connector and it has been working. Unfortunately there isn't a 100% guarantee though.
__________________
Tags
1c3f18c815ab, diagram, frdnaux, pn, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
