I am plum worried about running my stock pan dry whenever I drag race my friend and dad. So far there is no problems but when Im punchin it I wind her up to 4500RPM and I just wanted to know if it would ge acceptable to run 1 or 2 quarts more oil in the pan? The only reason im worried about overfilling it is becasue I dont want the oil to hit the crank and aerate it and of course lead to possible engine damage. So what should I do?
When you install the windage tray, you need to verify that the oil dipstick doesn't ride up on top of it when it shoved back down the tube. I've had three or four trays now and all needed modifying to cure this problem. When the dipstick rides on top of the tray, the crank will break it off.
