A4LD transmission rebuilds, experiences. - Page 5 - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
  #61
Old 05-06-2013, 12:48 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Again, problem with that Pablo. None of the parts you are referring to exist in the US. There is a lot of stuff in the European markets that is not available in the US.
There are no bolt on conversions to mate a 3.0L or 4.0L to a T5. There is a bellhousing to mate a 2.3L to a T5, in fact those are pretty easy to get here.
If you have the ability to fabricate a custom bellhousing, its not that difficult, but mating the Dana28 is a bit more complicated.
The only manual trans that will mate to the 3.0L or 4.0L easily is the M50D manual trans from the Ranger, but that is a major downgrade from an A4LD. The M50D is plagued with weak gears, sloppy build quality, lousy synchros. If you are gonna go through the trouble of converting to manual, the T5 is the best way to go, getting something that is weaker than the stock auto.
But a properly upgraded A4LD does not have to be expensive, and because its what the vans came with, there are no adapters of any kind needed.
  #62
Old 05-06-2013, 07:55 AM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
M5OD is used on Mazda E series vans. Small Asian van.. there are in use in Lugansk as EMS vehicles for narrow urban areas. And I know that tranny is not so good. too many problems with noise , OD and countershaft wear.
I broke 4R100 doing front seal - help!!?? SkySkiJason 1999 - 2003 7.3L Power Stroke Diesel 6 07-06-2016 09:01 AM
97 F250HD Trans Rebuild Akdog New Member Introductions 2 01-20-2015 11:37 AM
A4LD - 4R44E and 4R55E 96_4wdr Aerostar 6 12-13-2012 11:48 AM
Sprag?? tjthegreat Clutch, Transmission, Differential, Axle & Transfer Case 0 02-18-2010 10:06 AM
Building a better E4OD George D. 1994.5 - 1997 7.3L Power Stroke Diesel 15 01-09-2010 09:56 PM
Tags
a4ld, automatic, comparison, ford, leak, leaks, manual, problem, problems, rebuild, reverse, service, tcc, transmission, vehicles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
