Reading through a few past posts and threads I saw something that caught my attention... the 4.0 engine knock topic... While reading it, it sounded an aweful lot like what I am getting, then I saw that it is only happening at cold operating temperature... Is this (pri. tensioner) what is probably causing a rattle or chatter while the engine is slack, like coasting under very little load down the highway? As soon as I put it under load it quiets up and runs like a champ. If this post is redundant I apologize. Worst case scenario I keep it to the floor everywhere I go.
I too had a similar problem with my ranger, however, after taking it to the dealership, it was discovered to be a loose rear converter shield. just a thought.
