DashDaq-XL
DashDaq-XL
The DashDaqII is no longer available. It has been reppaced w/ the DashDaq-XL. DashDAQ Software and driver updates will continue to be forward compatible with the DashDAQ-XL and backwards compatible with the DashDAQ series II. If you have a DashDAQ Series II, you will still be able to get the latest software and drivers. We are also considering a special upgrade offer for existing customers.
DashDAQ • View topic - DashDAQ XL Information
Wow -now that was embarrassing! I didn't even notice the date of that post BigRy. What is interesting, and I guess the reason for me thinking that the XL was new, is that the Drew site (on the order screen) still lists the DasDaq Series II.
William - I am ordering one this morning! - w/ the Ford enhanced bundle - $644. Finally getting around to spending the Christmas $$'s.
First DashDaq disappointment -
I have read on the DrewTech website that the DashDaq will only read FICM voltage to 31V. It appears that the unit cannot be used to verify FICM health.
On the other hand, there is help on the website that indicates with add-on electronics, fuel pressure and egt READINGS might be possible.
I will keep ya'll informed of what I find (I am still excited).
Just a couple of things, DD FICM issues: I have not as of yet figured out what the unit actually reads. It shows something but I haven't been able to get any info from Drewtech as to what the readings actually mean.
Fuel pressure and EGTs are indeed available with additional hardware. I use Innovate products and have been successful. I know others have been using USBPhidgets and have also had good luck. The hardware you choose is entirely up to you.
I think you will be quite happy with the DD based on how many configurations are available and how many things you can look at at one time
Have fun with the new toy.
on
I believe you are talking about the widgets, or something like that, that they use from 3rd party companies to get those readings. There are a few on here that use the Spartan tuner that have them for the EGTs, I don't know about the fuel pressure readings though.
I think you also have to upgrade the firmware as well in order for those sensors to be read.
Mark,
Do you have a parts list for the fuel pressure and EGT add-ons?
What made you choose Innovate over Zeitronix or Phidgets?
I got cheap and did not get the GPS system. I already have a GPS. I may regret having to manage two units though ......
I must say the Innovate product was a breeze to connect and set up. I chose the LMA-3 box to start with which gives me a dedicated EGT channel and 4 more inputs which I can configure as desired. It also comes in a nice self contained box, not an open to atmosphere PCB. For the EGT probe I just used a K-type thermocouple I had left over from a previous job.
That being said if I was only going to do EGTs I may have chosen Phidgets due to their cost.
As for the fuel pressure sensor, any pressure sensor with a 0-5V output range will work for you. I bought this one from Innovate and it does the job nicely.
I think the Zeitronix ZT-2 is a good product, I just didn't need any of the oxygen sensor hardware that comes with it and the LMA-3 was a little cheaper.
If you have any other questions please let me know.
