6.0 Air Filter Change..?
Old 09-05-2004, 12:53 PM
LCinNC's Avatar
LCinNC
LCinNC is offline
Had my '03 6.0 SD in at dealership for a small adjustment the other day, and as it was about to turn 15k miles, decided to have them change the fuel filters the first time, while I watched. (Expensive lesson.. looks easy..)
I got to asking their premiere 'diesel guy' (looked to be about 19 years old) about changing the air filter. He told me it was "nearly impossible" for the average person and filters were only available at dealerships, and the filters were very expensive. He further stated that they had had several 6.0's turbos go out due to clogged and/or dirty air filters.
So - is the air filter change really that difficult ? If so, what makes it so hard?
Where else can you get the air filters without recieving a "motorcraft mugging" ?
Old 09-05-2004, 10:22 PM
jasonlasvegas's Avatar
jasonlasvegas
jasonlasvegas is offline
try napa #fil2731 about $75
Old 09-05-2004, 10:44 PM
eharman's Avatar
eharman
eharman is offline
Once you get the hang of it, you can change it out easily under 10 minutes.
You can get a stock air filter online at Fleet Supply for 49.95
, EJ
Old 09-06-2004, 07:19 AM
Rick Braden's Avatar
Rick Braden
Rick Braden is offline
Good priced filters for 6.0 psd & other engines
I would try www.filter1.com. They sell the 6.0 psd oil filters for under $12.00 & the airfilters for under $40.00. If you get a handfull of stuff, shipping is free & now tax.
Old 09-06-2004, 09:31 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
It IS hard the way Ford tells you to do it
but there is a description somewhere in here that makes it easy.... do a search....
if you take the WHOLE assembly out instead of breaking it apart like Ford recomends it is easy to change the filter off the truck...
(and I have 33K+ on my stock filter and it's still flowing great ! )
Old 09-06-2004, 09:59 AM
eharman's Avatar
eharman
eharman is offline
Ditto
EJ
Old 09-06-2004, 11:02 AM
04F250CC60's Avatar
04F250CC60
04F250CC60 is offline
I've got my filter changes down on my two trucks down to 5.349687836 seconds out and in. But then again I've done it 13 times !
Old 09-06-2004, 07:04 PM
SBV45's Avatar
SBV45
SBV45 is offline
Find another dealer service. This guy was telling lies. The filters are readily available. Yes it is difficult but not impossible.
Old 09-26-2004, 10:06 PM
ggrimm01's Avatar
ggrimm01
ggrimm01 is offline
Air Filter removal and replacement
Can someone from this forum guide me to where the removal and replacement instructions for the air filter are. I cannot find them. Thanks.
Old 09-27-2004, 06:35 AM
SBV45's Avatar
SBV45
SBV45 is offline
Try this:
http://home.austin.rr.com/sbv1/Proce...irFilterRR.htm
That is the hard way. Try removing the MAF wire connector, disconnect the hose to the degas (coolant overflow) bottle. Loosen the clamp from the intake to the turbo. Loosen the two rearward clamps on the air filter. Lift out the intake from filter to turbo. Loosen two front clamps on filter. Lift out filter and front air inlet. Replace in reverse order. (Don't you just hate that last piece.). Good luck.
run6.0run
12-25-2013 11:09 PM
F-WhiteThunder
1999 to 2016 Super Duty
13
12-06-2013 03:45 PM
lmorgan63
12-06-2013 12:45 PM
Mcrafty1
09-18-2013 11:38 PM
Quick Reply: 6.0 Air Filter Change..?
