Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Iowa Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Iowa Chapter Join Chapter, Leader: fellro86
  #1 (permalink)
Old 09-05-2004, 10:00 AM
fordloverf2501970's Avatar
fordloverf2501970 fordloverf2501970 is offline
Garage is empty, add now
fordloverf2501970 is starting off with a positive reputation.
hey fellro
i put that carb on just to fool with it a little bit. the chock was leaking so i switched it for my new choke on that carb i had on, well i started it up and lo and behold it started, just fooling with it is all right now, but it ran alot better then the other one did. when i rev it up it sounds 100% better, but it wont idle for very long, it defintly needs rebuilt, and i think it needs a thick gasket like that one we pried it off of. seems to have a major vacum leak with that little thin gasket i have on there now. just wanted to let you know that. i going to get a rebuild kit for it next week. hopefully when i come down again i will have it on so you can hear what you did for me. thanks again
__________________
Iowa chapter member
FTE supporter
If you can read this, thank a Teacher
if it is in english, Thank a Soldier !
Currently truckless and Laid Off!
but i am happy!
  #2 (permalink)
Old 09-05-2004, 10:25 AM
fellro86's Avatar
fellro86 fellro86 is offline
Iowa Benevolent Dictator
1978 Ford F-150
fellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud offellro86 has much to be proud of
It's been sitting for some time, and hasn't likley been rebuilt, so it isn't suprising it needs a little help, glad it works so far, hope it fixes the problem. The other definitely wasn't supplying enough fuel, from the looks of the left bank exhaust manifold, it looked like the exhaust was getting pretty hot too. Now you got an updated carb by 9 years...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles
the other workhorse 92 F350 2wd crew cab,3.55 rear axle, 92 6bt Cummins, NV4500
the project: 78 F150 4x4 shortbed 351 auto
Iowa Chapter leader, ASE certified parts specialist
Come on down and join us in the Iowa chapter, or your own local chapter!! Thanks, Roger
  #3 (permalink)
Old 09-05-2004, 12:32 PM
yeah i just took it back off going to run by autozone during the week and see what i can get for it, i couldnt belive how much a differnce that carb made that engine sound. is that carb also the cause of my manifold getting hot ? i wish i knew more about this stuff, that bowtie stuff doesnt carry over too well
__________________
Iowa chapter member
FTE supporter
but i am happy!
  #4 (permalink)
Old 09-05-2004, 01:33 PM
fellro86's Avatar
1978 Ford F-150
Running lean makes the manifolds run hot. Ever seen headers glow in the night? kinda cool but scary at the same time...
__________________
  #5 (permalink)
Old 09-05-2004, 02:36 PM
i'll have to be more carefull til i get that carb rebuilt, maybe i should richin up my mixture a little bit
__________________
Iowa chapter member
FTE supporter
but i am happy!
  #6 (permalink)
Old 09-05-2004, 02:38 PM
fellro86's Avatar
1978 Ford F-150
cast iron will take it better, but the idle mixtures should be reset, but won't have any effect on the road mixture, just idle
__________________
  #7 (permalink)
Old 09-05-2004, 05:29 PM
thinking now that maybe i should have brought this up when i was down there lol, i havent a clue about carbs or how to richen up idle mixture lol.
__________________
Iowa chapter member
FTE supporter
but i am happy!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
