1996 aerostar with the seat lumbar pump under it and want to hook the rear spring lift bags line into the air pump for the lumbar seat will this work?I don`t need more then 10 lbs of air for the bags.
Simple way to check; hook up a pressure gauge to the pump and see how high up it will go. Even if it puts out more than 10 psi, you will be holding that button down for a really long time to pump up air springs, and you will still need some kind of one-way valve to keep the air in them. I would not rely on that tiny pump to support my suspension.
I have one of the pumps out and was thinking it might work for that but I have my doubts. Doesn't seem to have much ommmf..but it might. I could put a psi gauge on it for you..
