I am getting a shimmy when braking at highway speeds.
The front brakes have recently been replaced about a year ago, including one rotor. I noticed the shimmy on vacation this week when exiting the highway or slowing suddenly at highway speeds. The van is a 92 extended and has 145,000 miles on it with the 3.0 engine.
What is causing this problem?
Thanks in advance
Jeff in Louisiana
Thanks in advance
Jeff in Louisiana
For what it's worth, I had the same symptoms after tire rotation at a shop. I then loosened the front lug nuts on both wheels, and retightened manually with a torque wrench. Shimmy went away. Too tight lug nuts can warp the rotors, apparently.
