1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
super duty dash removal
Old 09-02-2004, 01:40 PM
todd f.'s Avatar
todd f.
todd f. is offline
I have a 1999 f-350 4x4 deisel . I would like to replace my cracked speedo lens . Could anyone give my a step by step to remove my dash or point me in a direction. Thank Todd
Old 09-02-2004, 02:03 PM
n578md's Avatar
n578md
n578md is offline
Hummm, I did that just yesterday, although on a 2003 but they are the same.
First, I took the headlight and dimmer switch panel off. I used a small flat blade screw driver. There's a small notch on the bottom of the switch for you to insert the screwdriver behind which is the first retaining clip. Insert it about 1 inch and pry gently. There's no notch on the top but the retaining clip sits a little to the left of the dimmer wheel, along the top edge of the switch. Again insert the screwdriver deeply or you'll be pulling on the black
cover instead of the switch body which will damage it. There are two connectors to undo with a small push tab on each.
Second, take the radio out. I got radio pull-out tools at O'reilly for 7 bones. Put the U-shaped tools on each side of the radio, grab the tools and put leverage on the tool away from the radio and pull at the same time. There's the main connector with a push tab and there's the radio antenna which is just a push-in banana plug. No big deal.
Third you'll have to remove the two 7mm bolts that are located above the radio, on the under-side of the dash panel. Easy enough.
Fourth, if you have tilt wheel, set the steering wheel all the way down. That will facilitate taking the panel off greatly.
Fifth, there are I think 7 or 8 push-clips that are undone simply by pulling the dash panel. I pried them gently straight out with my hands at the edges of the panel. No tools needed. Pull the area around the steering wheel very gently as that area is very thin and fragile. Also be carefull at the passenger side area. You want to pull gently there too because of the powerpoit and airbag disconnect switch wiring. The airbag switch is a push-tab connector while the powerpoint is a harder to remove connector. You'll need the small flat blade screwdriver to push the tab in and pull that connector out.
That's pretty much it. The instrument cluster is held on by 4 7mm bolts and has 3 connectors towards the top of the cluster. One large one on the left, two smaller ones on the right.
On edit: This was on an 2WD XL model with a manual transmission. Obviously you'll have more stuff to unplug if you have ESOF and such. There are a few minor differences between models such as there's no airbag cut-off switch on crew cabs. Also, to remove the instrument cluster on a vehicle equiped for handicapped/elderly persons (automatics), you'll have to remove the transmission range indicator (the PRNDL needle doohickey) first before removing the cluster.
Old 09-02-2004, 02:25 PM
FortyFords's Avatar
FortyFords
FortyFords is offline
Only 1 suggestion ,disconnect the battery ! we don't want to read ,you fried your computer .
I know I just took all the fun out of this !
Rich
Old 09-03-2004, 08:06 PM
todd f.'s Avatar
todd f.
todd f. is offline
Thank you. n578md & FortyFords for the info. God Bless.
The following users liked this post:
Old 08-18-2010, 06:05 PM
RickMN58's Avatar
RickMN58
RickMN58 is offline
what if the radio is stuck ? Are all factory radios intechangable ?
72CC428
WTB - Ford Trucks & other vehicles
04-23-2016 07:34 PM
Todd Wenke
11-07-2015 05:10 PM
Tombstone Todd
15
11-29-2012 01:10 PM
Tombstone Todd
17
11-19-2012 07:50 AM
todd jo
06-30-2009 08:08 PM
Quick Reply: super duty dash removal
