Does anybody run biodiesel?
Ford's position on biodiesel
Here is something from the Ford Bulletins:
Ford's Position on Biodiesel:
Ford is advising that any of their vehicles powered by a diesel engine, regardless of manufacturer, may exhibit engine or fuel system problems when using fuels with greater than 5% Biodiesel. Any problems when using fuels containing more than 5% Biodiesel should be referred to the fuel manufacturer. Ford only recomends using fuels containing no more than 5% Biodiesel (B5) in their diesel powered vehicles. In addition, as per World Wide Fuel Charter (WWFC) catagory 1-3, fatty acid methyl esters (FAME) must meet EN14214 and ASTM D 6751 specifications. Broadcast Message 0884
Just something to consider.
Everything I have come across is that biodiesel blends are much more expensive.
That is interesting because I know that Cummins, as well as a handfull of diesel engine manufacturers have said it's okay to run straight biodiesel. Do you have ballpark figures on cost per gallon? This is funny because everything I'VE read said it's the same cost if not cheaper. Maybe two differant groups of people pushing two differant agendas? ;-)
trevorrules
18
04-18-2015 08:47 AM
DynamoDale
Bio-diesel, Propane & Alternative Diesel Engine Fuels
02-29-2012 11:00 PM
drewdole
18
04-29-2011 08:18 AM
