Setting Ignition Timing '96 4.9 - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 09-01-2004, 07:23 PM
Phantom Phantom is offline
Phantom is starting off with a positive reputation.
Does anyone know the proper procedure for setting the timing on a 4.9 six? The Emissions decal under the hood says "Timing is electronically controled and not adjustable" but the distributor has a normal clamp down.
The van pings bretty bad and I think someone may have played with the adjustment.
The distributor has a pickup in it as well as there being a crank angle sensor on the dampner. Plugging in a scanner to the OBD2 port I can see the timing advance is 10*, If I turn the distributor I can get the timing to advance on the scanner but I can't get it to retard any less then 10*. One manual says to disconnect the SPOUT Connector but there is none that I can find and this info is usually on the Emissions decal IF the timing is adjustable.
Anyone know the dealer or factory set up procedure?
Old 09-01-2004, 07:39 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
Follolw the wires coming off of the distributor, all the way to the ignition module, there should be what looks like a jumper in one wire, pull it out, set the timing with a light to 10*, then clamp it back down. It may also be in desperate need of a tune up.
Old 09-01-2004, 07:55 PM
There is no timing mark on the damper, There is a scale on the timing cover though.
Old 09-01-2004, 09:29 PM
cocot's Avatar
cocot cocot is offline
cocot is starting off with a positive reputation.
The scale you see when you look down from the front of the engine is not the right one. If I remember correctly the scale is located on the passenger side more towards the floor. I hope this helps.
Old 09-02-2004, 04:26 PM
Hey Guys Thanks!
I was able to locate the spout connector near the TFI module on the fenderwell unde the hood and the timing pointer is on the opposite side next to the crank sensor with the degree markings on the damper.
Set the timing to 10+* and no more pinging.
Bronco 1978 Vacuum Schematic and Emissions hcodi 1978 - 1996 Big Bronco 2 11-19-2016 02:36 PM
1996 4.9L Timing davemcnitt Ford Inline Six, 200, 250, 4.9L / 300 8 11-18-2016 07:46 PM
Setting the Timing on a 4.9L EFI Building_Fords 1987 - 1996 F150 & Larger F-Series Trucks 2 10-12-2016 10:44 PM
Timing advance on 1993 4.9l Thedonk 1987 - 1996 F150 & Larger F-Series Trucks 7 08-21-2016 12:57 PM
1986 4.9l distributor ModelTdriver 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-24-2015 07:07 PM
Tags
49, 96, adjustment, cylinder, f150, ford, ignition, module, motor, pointer, set, setting, spout, straight, timing, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
