Looking to wire up a homemade Idle controller on 2002 PSD!
Old 08-25-2012, 03:41 PM
Mike Hannahs's Avatar
Mike Hannahs
Mike Hannahs is offline
Thanks for the help Big Al,ill go check it out.
Old 08-25-2012, 06:54 PM
BIG-DADDY-F350's Avatar
BIG-DADDY-F350
BIG-DADDY-F350 is offline
I would be really careful with what you are doing. I just had a $900.00 repair bill that was caused from trying to wire in a homemade AIC like the one you are working with. Some how it causead a short in the system and took out the PCM and fried a couple of wires in the hareness from the PCM to the fuse box. BE CAREFUL!!!!
Old 08-26-2012, 02:41 PM
Mike Hannahs
Im glad you told me that,i was messing with it the other day and trying to wire up that set up and all of a sudden my engine reved up way high for a sec then stopped and went to idle again i thought i fried something for sure but i got lucky,i wont do that again,im going to get a DP Tuner or a TS and have it burned on it or go with the DFUSER AIC,thanks for the waring big daddy,its sure nice to have people chime in on there trial and error im doing messing with it i learned a good lesson, it scarred the **** out of me i thought at first it was going to runaway on me hahaha
Old 08-08-2013, 12:18 PM
chops3131's Avatar
chops3131
chops3131 is offline
Drawing
does anybody have a drawing
Old 08-08-2013, 04:03 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
What model truck do you have? Is it an automatic? If so, is it the PTO type?
Old 08-10-2013, 07:00 PM
chops3131's Avatar
chops3131
Thanks I figured it out I put it on my 01 ex works great. I added a led and used a push pull switch here is a link to the video
Old 08-10-2013, 07:05 PM
chops3131's Avatar
chops3131
Got it
Double post sorry damn iPhone
Old 10-21-2013, 10:49 PM
rezrocket6.0's Avatar
rezrocket6.0
rezrocket6.0 is offline
DIY AIC Mod (High idle) instructions from http://www.northtexaspowerstrokes.com/mods/aic/ - YouTube
what instructions did you have to do this mod? Great video
Old 10-22-2013, 09:25 AM
chops3131's Avatar
chops3131
Thanks I put the info in the title of the video. Look at your reply where you quoted me. Hope that helps. I did kinda modify it a little.
Old 10-22-2013, 10:45 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
great work, chops....ok, if your trucks' equiped with that "dummy" plug under the dash, that, i guess, is for the FORD aux idle control, can you usethem wires to rig up a DIY control idle?
Old 10-22-2013, 01:17 PM
chops3131's Avatar
chops3131
Not sure I found it but I could not find a rock solid write up on it, so I went with the one I posted. It works great
Here is the direct link:
dieselweisel
07-25-2017 10:56 AM
johnsonjf
11-16-2015 07:59 PM
Rocketattack
63
01-05-2011 09:45 PM
mystic201
12-28-2010 04:23 PM
dbblair
New Member Introductions
11-12-2007 06:51 PM
Quick Reply: Looking to wire up a homemade Idle controller on 2002 PSD!
