stock rim wide tire?
A 16X7" rim is designed to hold a maximum size tire. A 35" tire exceeds that recommended size and diameter. As windyhill pointed out, a 285 or 295/75X16" tire will fit without fitment or rubbing problems on turns. A 315 will hit on full wheel turn, especially in rough terrain. If you decide to go 35's, I concur with windyhill that a larger rim like a 10" rim would be the way to go.
Hope it works out for you... and Welcome to FTE!!!
Daryl
Daryl
Check out Super Swamper SSR's
Originally Posted by emag
I've tried searching for this but couldn't quite find an answer. Is it unsafe or are there any draw backs from mounting a 35X12.50X16 tire on the factory 16x7 rim?. Does anyone make a 35X10X16? Thanks in advance.
Model #SSR-41R
Size 35x10.50R16LT
Ply rating 8
Tread depth 21/32
Tread width 9.0
O.D. 35.3
Cross Section 11.1
Rec. rim 16x7-9
Max. Pressure 65
Load rating 3415
It's not an E-rated 10 ply tire but does have a good load rating for a 8 ply. I have been thinking of running these, but haven't got the lift kit yet. I like the height of 35 inch tires, but don't want the rolling resistance of the 12.5" tire. I haven't heard how the SSR handle or wear, these are just my observations while searching for tires.
CPerry
06-03-2003 08:09 PM
