ROMP-ROMP and die on warm startups
Hmm that should be recent enough oil change. Well I would start by checking all the sensors. Unplug and clean if necessary. If the engine wash is really the culprit you may have run some dirt and/or water down into one of the plugs. Did you use a pressure washer? Or a degreaser and water hose?
Just Simple Green and a garden hose.
That night it did something really wierd when I made a run to the store - when I left my house and took off up the hill it felt relly sluggish. by the time I was about a block away, I had to have it floored to maintain 15mph. When I let off at the top of the hill it died. Restarted right away and ran fine. Since then, if I don't let the glow plugs cycle long enought when warm, it romps a couple of times and dies.
Originally Posted by Kwikkordead
What do you think guys? HPOP pressure sensor? Complete loss of fuel pressure and needs the glow plug time to build back up? If this was a VW I would say MAF but it's a PSD and it does not have a MAF, I am still learning myself here.
