Changing a Fuel Filter 2001 F-150 - Ford Truck Enthusiasts Forums
Old 08-31-2004, 09:35 PM
Torb968 Torb968 is offline
Torb968 is starting off with a positive reputation.
Question Changing a Fuel Filter 2001 F-150
Can anyone provide some instruction on changing a fuel filter on a 2001 F-150 SC 5.4L?
Thanks
Old 08-31-2004, 10:52 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Yep, you first need to depressurize the fuel system. on the drivers side near the kick panel, there is a fuel shut-off inertia switch. Unplug it and crank the truck until it won't start.
Then, using the proper fuel line tool (available at mast any auto parts store), insert it into one of the fuel line fittings and pull the line from the filter. Some gas will come out, so watch your eyes. Repeat on the other line. Remove the filter from the mount and install the new one. Push the lines back on as far as you can get them, then tug on them to make sure that they are secure. Plut the inertia switch back in. Turn the key on for 5 sec. then turn it back off. Repeat 5 times. Then start the truck and look for leaks immediatly.
The filter is located on the drivers side framerail about under the rear seat.
Old 09-01-2004, 05:46 PM
Thanks for the info I'll tackle this this weekend. I had one changed around 43K at a jiffy lube and it took the guy all of 10 mins so I'm thinking it can't be that hard.
Old 09-01-2004, 08:49 PM
LxMan1's Avatar
NAW, I did mine about a month ago. About 10min's to do it myself.
How do I turn off the "water in fuel" light vfer98 1999 - 2003 7.3L Power Stroke Diesel 25 09-22-2016 10:35 AM
2001 F450 problem... Concrete guy josh 1999 - 2003 7.3L Power Stroke Diesel 8 06-07-2015 01:55 PM
Jumping at 45 mph LEWIS2001 Modular V8 (4.6L, 5.4L) 3 04-24-2015 04:50 PM
7.3 won't run Shiner527 1999 - 2003 7.3L Power Stroke Diesel 3 12-21-2013 07:19 PM
hard starting 2001 F250 diesel TinCocodrie 1999 - 2003 7.3L Power Stroke Diesel 14 06-30-2008 12:52 PM
Tags
01, 150, 2001, changing, f150, feul, filter, find, ford, fuel, fuelfilter2001, inertia, pressure, release, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
