460 Build for towing - Ford Truck Enthusiasts Forums
Old 08-31-2004, 07:45 PM
1stF250 1stF250 is offline
1stF250 is starting off with a positive reputation.
I have a 1979 F250 with a 460 c-6 and a Dana 60 with 3.54 gears. I want to build the motor for more towing power. How would you guys build this motor.
Old 09-01-2004, 01:26 AM
mako5972 mako5972 is offline
mako5972 is new and has a neutral reputation at this point.
If torque is what you want, start with Comp Cams XTREME 4X4 cam. Even if you don't have a 4x4, look at them. Go to www.compcams.com the page numbers are 102 and 103. Or you can give them a call at 1-800-999-0853 and they can assist you if you tell them what you want to do.
Old 09-07-2004, 09:01 AM
Tony G Tony G is offline
Tony G is starting off with a positive reputation.
I'm trying to build an engine for towing using the clevite/melling towing cam that mad dog racing is pushing on ebay. The intake lift isn't as high as on a 4x4 extreme cam, but the exhaust lift is good. Power is supposed to be from Idle to 4400 RPM's. I don't think I should have to go over 4000 RPM's as in 3rd gear and 3.55's 4000 rpms pulls 10,000 lb. up most hills doing 60 mph. If you REALLY, REALLY want pulling power, try stroking it with a roller cam conversion, roller rockers and mild porting or aluminum edelbrock heads. Probably have to go away from the RV cam that I mentioned because of the mild intake lift, but I can't say that for sure. A mild intake lift would sure cause some swirl effect in the intake track.
Tony
Old 09-07-2004, 03:39 PM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Have you tried the 460 Engine forum?
Possible motor swap 91 7three 1987 - 1996 F150 & Larger F-Series Trucks 10 01-19-2016 08:30 AM
383 or 408? BRay09 1987 - 1996 F150 & Larger F-Series Trucks 13 10-21-2015 09:27 AM
Need help with choosing turbo! 1970Ford460 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 2 10-18-2015 01:14 AM
83 460 5th wheel hauler build N.W.Ford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 09-21-2014 06:58 PM
5.8L /460 swap comet 1987 - 1996 F150 & Larger F-Series Trucks 4 08-05-2002 11:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
