loss of power - Ford Truck Enthusiasts Forums
loss of power
Old 08-31-2004, 11:53 AM
super_ranger super_ranger is offline
super_ranger is starting off with a positive reputation.
loss of power
my friend has a 94 ranger that lost power. its a 2.3 one of the coils is dead it aint getting no power in but the coil is good. no CEL. itstarted about a month ago. just when it was cold. but then it got worse. now its all the time. between 45 and 60 its real bad. i dont think the secondary coil ever worked because its always been gutless compared to my 91 2.3. tonight im going to run a jumper wire to the b+ wire that runs to the coil and see if that does anything. but what i was wondering why it would just get gradually worse. i was thinkin fuel filter. any other ideas would be nice
Old 08-31-2004, 10:34 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Have you checked for stored codes?
Here's a link to the Ranger board's Technical Information sticky:
http://www.ford-trucks.com/forums/sh...d.php?t=107538
The 94 is EEC-IV. There's enough info there to bring you right up to speed with the system. You'll need a multimeter (VOM) to pull codes.
There's some very expert guys on the Ranger board that would be happy to help you through this problem.
AL.
Old 09-02-2004, 01:01 PM
the check engine light aint on so i didnt think there would be any.
Old 09-02-2004, 10:00 PM
Dealford's Avatar
Not being an expert myself, I'm just suggesting a complete inspection. I'm sure that I've read on the Ranger forum about stored codes with no light.
If you were to post on the Ranger forum, the guys there (lots of experts) could walk you through your problem step by step. There may be answers to the problem that are not at all what a regular guy would come up with AND would solve the problem.
AL.
Old 09-09-2004, 11:14 AM
Vin 95 Vin 95 is offline
Vin 95 is starting off with a positive reputation.
The light does'nt have to be on to have stored codes. off hand I would suspect the throttle possition sonsor (TPS) when it goes bad it tells the computor(PCM) not to open the fuel injectors. They will slowly go out.
OBD 1 code 224 ! HELP ! navag8ter Ranger & B-Series 13 10-05-2013 09:07 PM
coil arching 410F-100 1973 - 1979 F-100 & Larger F-Series Trucks 8 09-18-2012 07:25 AM
89 ranger 2.3 no spark sims95 Ranger & B-Series 8 02-15-2012 10:25 AM
truck missing out f250d4x4 Ranger & B-Series 11 01-16-2012 07:12 PM
'93 Ranger 2.3L 5-Speed 2WD - No power? Kijutsu Ranger & B-Series 10 03-13-2005 12:05 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
