Unerdrive trans
Type “auxiliary transmissions” in your web search engine and you should find lots of potential vendors. MSN turned up over 11,000 hits. I did not see anything for the M5OD transmission, but surely somebody makes one or would modify the mounting system to work for you. If nothing else, call Advance Adaptors @ 805-238-7000 and see if they offer an adaptor kit for the M5OD or can give you any ideas where to begin looking.
Another option might be to look for a two-speed differential. I have not seen one of these in years, but they used to be available for one-ton trucks so you might be able to find something that would fit in the F150.
It could be a myth but I’ve always heard you can’t use a transfer case strictly for gear reduction. Supposedly the torque reduction is all out of wack if you don’t use both drivelines and the internal strain will take out the bearing in short order. Who knows?
If it would work that would be a pretty easy solution…
