Towing capacity - 4.9L 6 cyl - Page 2 - Ford Truck Enthusiasts Forums
Old 01-07-2014, 11:08 AM
blue924.9's Avatar
blue924.9 blue924.9 is offline
blue924.9 is starting off with a positive reputation.
the 4.9 can tow more than the f150 can handle, just not lightning quick, i myself have towed 10,000 pounds with my 4.9 i think you will be fine, if you want i can supply pictorial proof of the 10,000 pound load
Old 01-07-2014, 12:06 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Quote:
Originally Posted by spiritartman View Post
How do I find out which Gears I have? and how much I can tow as well as max payload? Thanks.
Find the axle code on the drivers door pillar and compare it to the information in the link and what you find in your owners manual.
Ford Axle Code Chart .: Articles
Old 01-07-2014, 06:44 PM
spiritartman spiritartman is offline
spiritartman is starting off with a positive reputation.
96 F150 Inline 6 Towing ability and Gears
Thanks for the 2 replies - I'm new to this forum and trying to figure it all out.
As far as the inside of the door - I found out the color code of the vehicle as well as the axle and Gross vehicle weight load - what would the code be for the axles and gears? Any new info on the 96 F150 Automatic 2 wheel drive Inline 6 would be great - thanks all!
Old 01-07-2014, 06:46 PM
Quote:
Is that a Massey Tractor? - Send pics of the Inline 6 and what additions you have - weight distribution - breaks etc etc - I'm a newbie - thanks.
Old 01-07-2014, 07:16 PM
blue924.9's Avatar
nope, allis chalmers wd, my pulling tractor, dont have any pics of the inline six, and the only aftermarket parts i have on my truck is two 10 inch subs behind the seat and better front brakes, also with my 10,000 pound load i didnt have any weight distributing hitch on it, just a regular one, but i loaded the trailer with just a smidge more weight in back than usual, i still had enough weight on the tongue to engage the overload spring so i had alot of tongue weight. also i would NOT RECOMEND towing that much, especially if your a newbie. i was just reassuring you that the 4.9 is capable of towing more than the f150 is rated for, i also dont RECOMEND going above the rated towing weight in the owners manual, though i have done it many times
Old 01-07-2014, 07:49 PM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
Wow, the original post was 2004.
My F150 with the 4.9 and five speed was a decent towing rig. My main complaint is with the high first and reverse ratios, the other gears were well spaced. I did use overdrive but down shifted when engine vacuum dropped below 8" when I hauled a 3500 lb pop up. Hauling the 4500 lb fifth wheel Rv was pretty easy and I was able to maintain 55 to 45 mph speed limits on the back roads of southwestern Maine. Only used fifth going down hill above 12 " of vacuum with the bigger trailer.
Happy New Year
rikard
Old 01-13-2014, 04:05 PM
Nice Tractor!!! Thanks for the input. I think the Truck is rated for 8K lbs with weight distribution and 5k without it. (Although that seems rather light) I don't have the owners manual though.
Old 01-13-2014, 04:06 PM
Thanks for the info - I don't have the owners manual for the 96 F150 300 Inline 6 - do you know off hand what it was rated for as far as towing? Mine is Automatic Tranny. Thanks.
Old 01-13-2014, 06:33 PM
blue924.9's Avatar
with 3.08 gears regular cab long box, 5600 pounds max towing, remember these are older trucks with lower rating
Old 01-13-2014, 08:47 PM
Yes I do have the 308 Gears - Hmm so 5,600 is the max even though the hitch is rated for 8k with weight Distribution. I suppose most 24" trailers are not over 5Klbs anyway - that is why I sold my 87 Jeep Comanche for the higher towing ability of the Ford. I was hoping it would be rated for closer to 7K but 5,600 is fine and THANK YOU FOR FINDING THIS OUT FOR ME!!! Do you own a 96' as well? What State are you in? South Carolina is where I'm planning on moving to - I wanna learn farming.
Old 01-14-2014, 04:12 PM
mmb617's Avatar
mmb617 mmb617 is offline
mmb617 is starting off with a positive reputation.
Thanks guys, this has been an informative thread for me. I've been hauling my bracket car and trailer with a combined weight 5k lbs, 200 miles round trip to the track for years with my company vehicle, presently a 2012 Chevy Express van.
I will be retiring in the not too distant future and wondered if my '91 F150 with the 300 inch I6 and E4OD would be able to take over the towing duties. From what I'm reading here it sounds like it may be possible.
Old 02-27-2014, 04:12 PM
El Camino Man El Camino Man is online now
El Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to beholdEl Camino Man is a splendid one to behold
Resurrection? Lol
^^^ To answer your question, I wouldn't recommend getting too crazy with an E4OD. Theyre notoriously temperamental when it comes to towing & heat.
I was going to start my own thread but Ill just go off this one: Iv always been a fan of the 300, although Iv never owned one. The thought of good torque numbers and 20ish mpgs is enough to intrigue me!
I currently own a 2004 F-250 with the V10. Its a beast needless to say! But I cant get over 10 mpgs. Id like to go back to the old style trucks (80-97) and get a F-250, manual, with the 300 (did they come with ZFs?). Id be ok with swapping gears to something deeper, such as 3.73s or 4.10s if they didn't come that deep from the factory. I own a 5th wheel trailer weighing in at somewhere in the neighborhood of 8500 lbs. Would an ol 300 be up to the task? Other than pulling my camper a few times a year, that's pretty well all the towing I do
  #28
Old 02-27-2014, 05:48 PM
blue924.9's Avatar
Quote:
Originally Posted by El Camino Man View Post
Resurrection? Lol
read my above post, i believe its the first one on this page, your 300 will do fine, just wont do it lightning quick in the accelaration department, which is fine, sometimes i think they give the newer trucks too much power,(all it takes is 1 newbie tower to load it to the max and run 70 mph to create a bad situation) 300s did come in f250s although they are more rare than any of the other gas motors so it may take some time to find one, or you may have to swap the 300 out of an f150 into an f250 as i belive its a direct fit. good searching
  #29
Old 02-27-2014, 06:50 PM
Thanks for the info!
I don't plan on taking my camper on the interstate much, if at all. Most of the time, I take it 15 miles down the road.
If I cant find a 300 powered F-250, then I may do a swap. Actually, Iv wanted a reg cab F-350 dually with the 300, which of course was never made.
Will the 300 be able to retain 55-60 with my camper? My old IDIT would hold 55... if I kept my foot at exactly the point before it kicked down. If it kicked down, Id actually lose speed. I don't want that again lol
  #30
Old 02-27-2014, 07:28 PM
blue924.9's Avatar
well, it depends alot on the entire truck not just the engine, i know when i hauled the 10,000 pound load the trans hunted in and out of o/d alot so i locked it out after about a mile. after it was locked out it had no problem but that load didnt have alot of wind drag like a camper would but all in all would do it
SuperTruss: The cure to your hangover Torklift Sheryl Vendor Specials, Discounts, Product Announcements & Group Buys 0 08-06-2015 06:18 PM
Sort of a newbie on towing/trailering - need advice grey2112 2009 - 2014 F150 27 01-01-2014 10:34 AM
Increase towing capacity t. Haslo Expedition & Navigator 8 07-26-2011 11:00 AM
1989 F350 GVCW tow capacity? Jarniscipus 1987 - 1996 F150 & Larger F-Series Trucks 2 02-20-2011 02:01 AM
Towing Capacity Question pongolo Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 3 06-03-2010 12:14 PM
Tags
1981, 1993, 1994, 308, 49, 49l, capacity, capicity, cyl, end, f100, f150, inline, liter, pulling, rear, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
