Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 10-31-2009, 03:13 PM
Fishwhisperer Fishwhisperer is offline
Fishwhisperer is starting off with a positive reputation.
Racerguy, thanks for the quick response. I'll see if I can get it from the passenger side. Looks like I might have to move some electrical harnass wires out of the way. Maybe thats whats blocking most of it.
Thanks
  #17 (permalink)
Old 11-14-2009, 04:24 PM
I couldn't get to my camshaft postioning sensor without removing the plenum, even then it was under a harnass of wires. Anyways, the bottom line is that there are 3 different types of camshaft postioning sensor's for a 1995 Ford Ranger. The one I have does not just involve changing the top cap (being the camshaft positioning sensor). Mine is the CPS complete with synchronizer and stator. The Ford Dealer here cannot even get the Ford part. I can get an after market one (item # J12K073) for $600.00.
My question is:What if I just continue to drive it like this? What could happen? Would I just not get as good of gas mileage. Right now it just idles up and down alittle. The prevous owner says the service light has been on for the last 10- years that he has had it.
I'm looking at just putting it back together and driving it as is. If anybody else has driven it like this, I would like to hear some feedback on this.
Thanks
  #18 (permalink)
Old 11-17-2009, 05:09 PM
mdfan mdfan is offline
mdfan is starting off with a positive reputation.
Need help locating my CPS.
96 Explorer 4.0. Removed upper intake per service manual. Ive looked everywhere and cannot find this part. Some websites say its on the valve cover, some by the firewall. Ive looked for hours.
Please help! Ive got to get this car back together, thru emissions, etc.
  #19 (permalink)
Old 11-17-2009, 08:44 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all Rockledge is a name known to all
That doesn't look like an OHV 4.0L.
Are you sure yours isn't a SOHC 4.0L? If it is, then it will not have a cam synchro assembly like the OHV.
__________________
'98 Ranger XLT 4x4 (4.0L)
'97 Taurus GL (3.0L Vulcan)
'94 Taurus SHO (MTX)
Ford Pics
  #20 (permalink)
Old 11-17-2009, 08:52 PM
You are correct, its a SOHC. I dont know what that means with respect to the car.
Im trying to replace it due to a P0340 error- "Camshaft Position Sensor Circuit Malfunction".
  #21 (permalink)
Old 11-18-2009, 10:00 AM
Rockledge's Avatar
On the 4.0L SOHC engine (VIN E), the Camshaft Position Sensor is triggered by the high-point mark on the left-hand camshaft. It is mounted to the valve cover.
Ford Service Manuals - SOHC CMP SENSOR REMOVAL AND INSTALLATION
__________________
Ford Pics
  #22 (permalink)
Old 11-18-2009, 02:41 PM
Thanks for the replys and link
Im confused. The part I picked up does not look like the one in the drawing you linked. The drawing has only 1 bolt, but the replacement I purchased has 2.
Car Part Wholesale - Auto Parts and Accessories Catalog - Camshaft Position Sensor For 1996 Ford Explorer XLT 6 Cyl 4.0L
This link shows what I purchased. Ive also verified this part at 2 different auto parts places. What am i missing- are they selling me the wrong part?
  #23 (permalink)
Old 11-18-2009, 02:51 PM
RangerRule RangerRule is offline
RangerRule is starting off with a positive reputation.
1995 4.0 OHV Ranger Camshaft Synchronizer
Dealer says synchro. needs rpl at $1,200. $300 for more recent model that must be modified as the part for my 1995 is no longer available, plus $900 in labor. The only symptom I've noticed other than not great MPG, is an intermittent metallic whine or squeal. My CEL has not come on to indicate any sort of problem. Any INFORMED opinions on what (if any) actions I should take?
I've read the 3.0 & 4.0 threads on this matter. Thanks for your response.
  #24 (permalink)
Old 11-18-2009, 05:05 PM
Follow up.
With the diagram you attached, I easily located what I think is the part. The first photo has me pointing to the part, on the drivers side valve cover. The second photo shows the original part on the left , and the Advance Auto part on the right. Obviously, they are not the same.
So, do I have the correct original or replacement? This is crazy- i called the local Ford dealership, and he wasnt any help either. Im thinking the part I removed is not the correct part- isnt the CPS supposed to be riding on a part like a distributor? The original part is more like a plug- sort of like a pcv valve.
  #25 (permalink)
Old 11-18-2009, 05:50 PM
Rockledge's Avatar
mdfan, the problem I think you might be having is that the first year of the SOHC was supposedly 1997. Try telling the parts people that you have a '97 4.0L Single Overhead Camshaft (SOHC) engine and you'll get the right part.
__________________
Ford Pics
  #26 (permalink)
Old 11-18-2009, 06:06 PM
Rockledge's Avatar
I have read before that the '95 synchro assembly is indeed different, and that it's a little harder to find these days. I've also heard that you can find re-manufactured ones on eBay. Or you could check the local wrecking yards for a '95 4.0L Ranger.
$900 for labor is a joke. If you can find the correct part, you can put it in yourself. You'll have to remove the upper intake to get at it. For guidance on that, see: Replacing Ford 4.0L Upper Engine Gaskets
__________________
Ford Pics
  #27 (permalink)
Old 11-18-2009, 09:59 PM
You are a genius.
FWIW. This is/was my parents car, and they recently gave it to me. Door sticker says its manufactured Sept 06. Called Dad to ask if he every buys 97 parts, and he says "yes, its a 97".
Intake manifold back on. Picking up the correct part in the am. Thanks for the help!
  #28 (permalink)
Old 11-19-2009, 12:51 AM
Rockledge's Avatar
You are a genius.
A genius? Try telling that to.... well ...never mind. Glad I could help. Let's hope the new sensor clears up that P0340 code.
It sounds like you have what they call a Model Year (MY) 1997 Explorer, equipped with one of the first generation Ford 4.0L SOHC engines put into production.
__________________
Ford Pics
Tags
1999 , 2002 , 30 , 40l , 94 , angle , cam , code , crank , diagram , ford , located , p0340 , ranger , sensor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
