Draining the fuel tank
Old 08-28-2004, 05:26 PM
Karstonian's Avatar
Karstonian
Karstonian is offline
I have bad fuel in my front tank and need to get rid of it. What is the easiest/best and safest way to drain the tank? Any ideas or links would be appreciated...
Old 08-28-2004, 08:13 PM
gotdiesel's Avatar
gotdiesel
gotdiesel is offline
can you just us a small hose and drain it out though the filler neck??? syphon (sp?)it out until you get it as low as possible and dilute the rest of the fuel by filling up the tank. might be able to do it this way and not remove or undue anything. good luck
Old 08-28-2004, 08:44 PM
tuckr's Avatar
tuckr
tuckr is offline
home depot or menards has a little pump that you attach to your drill and it will pump it out. I use it to pump out the engine oil in my boat motor all the time and it was under ten bucks
Ricohman
6.7L Power Stroke Diesel
06-19-2015 05:50 AM
Slip ford man
11-15-2010 12:26 AM
kidoo
09-06-2008 12:44 PM
Chance_Thomas
06-12-2006 10:54 PM
MxRacer32
02-10-2005 05:53 PM
Quick Reply: Draining the fuel tank
