Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 08-28-2004, 12:31 AM
Brian460 Brian460 is offline
Garage is empty, add now
Brian460 is starting off with a positive reputation.
Brian Barker
'93 Lightning 10psi doggy? air/fuel??
My buddies lightning with a stock motor and a 10psi S-trim on it seems to be doggy sometimes like it has severly retarded timing and then the next stoplight it might run great.
He has an A/F ratio monitor in cab and it is always hanging out in severe lean condition now, even when running boost and 100psi fuel pressure.
It also has a rough idle condition sometimes it will flucuate between 300-1000rpm normally it idles at around 750 rpm.
Could this be the o2 sensor?
If anybody has any ideas that would be great we are out of them
__________________
'03 F-250 FX4 CC SB 6.0L Spartan Tunes, 4" Superlift, 4" Magnaflow, X-Monitor, 315/75/16, 4.30 gears
PSD Burnout
KD0FBK
  #2 (permalink)
Old 08-28-2004, 08:36 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
patfogle DaPocky
Sounds like a bad ground to me. I'd check the fuel pressure regulator too, and then put in 2 O2 sensors (one for his gauge, and one for the computer). It's possible that the computer is not gettin enough signal from the O2 sensor, or feedback from the gauge.
__________________
1996 F150 Regular cab, SWB, 4.9. 5speed.
- Life is like a roller coaster, Live for the ups.
- Negativity begets hate, hate begets ignorance, ignorance begets stupidity. Don't be stupid.
- If you have to ask "Will this hurt?" do not proceed!
  #3 (permalink)
Old 08-29-2004, 11:38 PM
Brian Barker
He has a mechanical fuel pressure gauge on the cowl so we know it is right. Going to replace the o2 sensor.
Where do you think it might have a bad ground?
__________________
PSD Burnout
KD0FBK
Tags
10, 93, air, doggy, f150, ford, fuel, lightning, meter, pressure, psi, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
