differential lubricant for a 4x4 1985 ford ranger 2.8l
Rear axle-Hypoid lubricant (Ford #EOAZ-19580-AA/spec # ESP-M2C154-A)
Front axle-Hypoid lubricant (Ford # C6AZ-19580-E/spec # ESW-M2C105-A)
After all that, just about any good hypoid 90w oil will work fine. If the rear end is a limited slip, make sure you add about 4 ounces of "friction modifier" to the oil.
19580, 1985, axle, c6az, c6az19580e, eoaz19580aa, equivalent, espm2c154a, esw, ford, hypoid, m2c105a, number, ranger, rear, spec
