Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-27-2004, 05:50 PM
ChuckRock ChuckRock is offline
Garage is empty, add now
ChuckRock is starting off with a positive reputation.
vacuum advance hose
I am trying to get an 83 truck running. It's a 83 ranger and has 2.3L. It has had all of the smog junk removed. It starts without much of a problem. But when you give it gas it does not pickup very fast and seems like it is boged down. I started checking for vacuum leaks and found that the vacuum advance hose is not connected to anything. I would think it should be connected to the intake somewhere. Can someone tell me if that is the case?
  #2 (permalink)
Old 08-28-2004, 03:32 AM
ClatonK ClatonK is offline
ClatonK is new and has a neutral reputation at this point.
There should be a vac port on the carb just for that purpose. In most cases the port will not supply vacumn until the throttle blades have opened up some. So it may not have a vac leak at idle but it will at crusing speed.
Clayton
Tags
23, advance, ford, liter, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
