my horn doesn't work - Ford Truck Enthusiasts Forums
Old 08-27-2004, 04:57 PM
jammin jim jammin jim is offline
jammin jim is starting off with a positive reputation.
Question my horn doesn't work
my horn does not work. what do i need to do, any suggestions first time working on vehicles, but i do have some knowledge, just not on horns-thanx
Old 08-28-2004, 09:44 PM
good 'ol ford's Avatar
good 'ol ford good 'ol ford is offline
good 'ol ford is starting off with a positive reputation.
the first thing to do would be to check and make sure that the horn is conected and if so see if there is power to it when the horn button is pressed. if not work your way back to the horn button to find where power is being lost. if there is power there u need a new horn.
Old 08-28-2004, 09:50 PM
thanks guys for all your help
Old 08-28-2004, 09:51 PM
hey not a problem
Old 08-28-2004, 09:52 PM
i see you are new to the site, too what kind of truck do you have?
Old 08-28-2004, 09:53 PM
truckfarmingcanuck's Avatar
truckfarmingcanuck truckfarmingcanuck is offline
truckfarmingcanuck is starting off with a positive reputation.
I've made the assumption that you checked the fuses but if not do that first, next:
1. Find the horn under the hood and check that the bolt holding it to the rad support isn't all rusted up. This is your ground, if rusted remove and scuff up the horn bracket with sandpaper, clean the bolt and re-install
2. Check the wire (connector) that is attached to the horn is not all corroded and full of green death. I think it should be a yellow/green wire if memory serves me right.
Try the horn
If still no good, check the horn pad on steering wheel
3. Horn pad can be removed with 2 screws that are fastened behind steering wheel itself. Horn pad plastic is notorious for breaking. You'll know yours is shot if it feels real flimsy wheel you pull the pad out of the steering wheel. If not broken check that the wires are in good condition.
4. If none of these you have a wiring issue. Depending on what yuo have planned for your truck you have 2 choices. Spend the time to find the loom problem and keep it original or run a wire to a push button switch placed somewhere convenient in the cab the is connected to the horn on the other end.
Good luck
Old 08-28-2004, 09:57 PM
i got at 77 f150, 351m, thats in pretty good shape
Old 08-28-2004, 10:04 PM
truckfarmingcanuck-i would bet that is what is wrong "a busted horn pad" i was thinking about putting in a button switch anyway this might save me the trouble- i see you are from canada there's a guy that lives near us that is from canada do you know any dechesneau's
Old 08-31-2004, 10:43 PM
WJM WJM is offline
WJM is starting off with a positive reputation.
Lost ground, No Horn
I am a new member and this is my first post. I have been helped by other members posts on ignition and maybe I can help with the horn problem. If the rubber universal has been replaced in the steering column make sure the ground was reconnected around the rubber universal. I ran a ground strap from the bolt on one side of the universal to the nut on the other side and the horn started working great. I am not sure how the ground was run originally but I am not going for show.
'77 F250 Camper Special with a 460.
First Truck. It is never too late to have a happy childhood!
WJM
Old 08-31-2004, 10:58 PM
V10KLZZ71S's Avatar
V10KLZZ71S V10KLZZ71S is offline
V10KLZZ71S is starting off with a positive reputation.
I seem to remember a horn relay under the hood on my 74,you might check.
Old 09-02-2004, 12:19 PM
ceekay1 ceekay1 is offline
ceekay1 is starting off with a positive reputation.
WJM
hello<> I coudl use your expertise on possible ignition issue? I posted today under my user name around 10-11 AM or so with the updates, (title is alternator discharge I think).
There's a lot in that post & don't want to crowd this one.. would you please take a look/see -- ceekay1
Also have a '77 four star 460+4bbl, auto,. eletronic after market ignition - california raised coach,. its a sparkler.. horn does not wrok and have switch on that one,. and have another post to find wiring colors or anything to help so I can hook the cruise control back up... TY!
Old 09-03-2004, 02:40 PM
Vin Man's Avatar
Vin Man Vin Man is offline
Vin Man is starting off with a positive reputation.
Horn Relay
Quote:
Does anyone know what this relay looks like and where it would be located on my truck. Both my trucks - 73 F100 and 76F150 don't have working horns. I was going to wire up switches, and would like to tie into the original relay instead up buying a new one from Checker for $7.
-Vinny
Old 09-03-2004, 03:01 PM
Colo79Ford Colo79Ford is offline
Colo79Ford is starting off with a positive reputation.
wiring diagram for 76-78 shows it on radiator support? Should have a yellow wire going to starter relay, and a yel/blu wire going to the horn switch, if im reading this diagram right. These could be crap diagrams too, will someone correct me if im wrong here?
---JOHN
Old 09-03-2004, 05:38 PM
Vin Man's Avatar
Thanks John
Old 09-03-2004, 09:44 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
The horn relay for a cruise control option truck is located under the instrument panel to the left of the steering column. That is for a 79 model, not sure on the 78 and earlier but I would imagine they are the same.
If the relay does not work go out and buy one of them AAAUUUUGAAA horn's!!
Horns lewis racing 6.0L Power Stroke Diesel 11 10-01-2014 01:41 AM
Help with Horn Contact Duckmang 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-29-2013 12:40 AM
horn won't work F350moneypit 1973 - 1979 F-100 & Larger F-Series Trucks 19 02-04-2013 02:46 AM
Horn Horn Horn---very weak GormGorm 1987 - 1996 F150 & Larger F-Series Trucks 2 04-05-2010 12:21 AM
64 F-100 Horn problem sleddog60 1961 - 1966 F-100 & Larger F-Series Trucks 5 05-18-2009 10:29 PM
Tags
1966, 1999, 76, doesnot, doesnt, econoline, f100, f250, f350, ford, horn, sound, supercrew, truck, wiring, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
