airbag fuse - Ford Truck Enthusiasts Forums
airbag fuse
Old 08-26-2004, 09:01 PM
cdkon cdkon is offline
cdkon is starting off with a positive reputation.
airbag fuse
Does the airbag fuse automatically blow if there is a code being displayed? I have a code 12 meaning low battery voltage and I am wondering if the voltage is low to the airbag system because the fuse is blown or if low voltage from the battery is making the fuse blow......Chicken or the egg first!!!
Everythime I try to replace the fuse it blows.
Thanks for any advice
Old 08-26-2004, 09:12 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
The air bag diagnostic monitor (14B056) measures the voltage at pin C209-14, circuit 937 (R/W), of the air bag diagnostic monitor connector. Voltage at pin C209-14, circuit 937 (R/W) should be equal to battery voltage. If the voltage at pin C209-14, circuit 937 (R/W), drops to less than 8 volts, the air bag diagnostic monitor will flash a lamp fault code (LFC) 12 on the air bag indicator. If the voltage at pin C209-14, circuit 937 (R/W), drops to less than 5 volts, the diagnostic trouble code (DTC) B1867 will also be stored in memory. Should the loss of battery voltage at pin C209-14, circuit 937 (R/W), be intermittent or repaired, the air bag diagnostic monitor will flash a LFC 52 (or higher priority code if one exists) on the next ignition switch cycle.
Possible Causes
WARNING: DO NOT UNDER ANY CIRCUMSTANCES SUBSTITUTE ANOTHER FUSE VALUE FOR THE 10A BATTERY FUSE 2. ANY FUSE OTHER THAN 10A MAY CAUSE DISARMING FAILURE AND MAY RESULT IN DANGER TO THE OCCUPANTS OF THE VEHICLE. DO NOT ATTEMPT TO REPLACE THE 10A FUSE 2 UNLESS THE AIR BAG SYSTEM FIRST HAS BEEN DEACTIVATED. (REFER TO THE DEACTIVATION PROCEDURE IN THIS SECTION).
NOTE: If a short to ground exists on any of circuits 607 (LB/O), 614 (GY/O), 615 (GY/W), or 616 (PK/BK), 1112 (W/LB), 1113 (Y/LG), leading to a LFC 13 or 53 and DTC B1913 or similarly a short to ground exists on any of circuits 617 (PK/O), 619 (PK/W), 624 (Y/W) or 625 (Y/LG) leading to a LFC 14 or 54 and DTC B1914 the air bag diagnostic monitor will activate an internal solid state switch at pin C209-13 of the air bag diagnostic monitor. This causes the battery fuse 2 (10A) to blow, thus disarming the air bag system and preventing inadvertent air bag deployment. If the power distribution box battery fuse 2 has blown, it must be replaced by a 10A fuse.
Low voltage at air bag diagnostic monitor pin C209-14, circuit 937 (R/W), can be caused by:
An open in the battery circuit that would prevent battery positive voltage (B+) from reaching the air bag diagnostic monitor pin C209-14, circuit 937 (R/W).
A short to ground on the battery feed circuit between the fuse 2 (10A) and pin C209-13, circuit 937 (R/W), or pin C209-14, circuit 937 (R/W), of the air bag diagnostic monitor.
A concern in the charging system causing battery voltage to drop below 8 volts.
After the air bag diagnostic monitor has disarmed the air bag system, it will not be enabled until the appropriate condition (DTC B1913 or B1914) has been repaired and cleared by performing the appropriate pinpoint tests
SRS 44 jonesg 1968-2013 Full Size Vans 2 08-14-2014 08:18 PM
1994 E-150 Airbag Problem bwelchel 1968-2013 Full Size Vans 0 11-02-2013 09:29 PM
Airbag error diagnostic low battery voltage code 12, pin 13 & 14 are only 2.8 volts on 95 Aerostar grostig Electrical Systems/Wiring 4 07-27-2013 10:51 AM
Airbag error diagnostic low battery voltage code 12, pin 13 & 14 are only 2.8 volts on 95 Aerostar grostig Aerostar 4 07-16-2013 12:48 AM
Airbag code 52 on 98 F-150 CALF150 1997 - 2003 F150 4 02-22-2008 02:47 PM
Tags
1997, 2000, 2002, 2004, air, airbag, b1867, bag, c20914, code, f150, ford, fuse, location, number, taurus, vanl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
