1980 302 bolt to small bolt pattern transmission? - Ford Truck Enthusiasts Forums
Old 08-25-2004, 04:20 PM
1964Ranchero 1964Ranchero is offline
1964Ranchero is starting off with a positive reputation.
Does anybody know if there is a bellhousing made by ANYONE that will mount a newer 302 up to a small bolt pattern T-10. The T-10 is original 1964 I believe (when the 289's used 5 bolt bellhousings), and I was hoping to not have to switch to a newer tranny. Thanks! MIke
Old 08-25-2004, 06:27 PM
Jimbare's Avatar
Jimbare Jimbare is offline
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
all you will have to change is the bellhousing, tranny can stay.
jim
Old 08-25-2004, 07:05 PM
And where can i find this bellhousing? Thats what i need to know, cause i cant find them anywhere.
Old 08-25-2004, 10:08 PM
Jimbare's Avatar
let me see if i can come up with some info for you. have you tried any yet on your tranny?
jim
Old 08-26-2004, 02:10 AM
Jimbare's Avatar
where are you located, that would help in finding a bell housing for you.
jim
Old 08-26-2004, 10:58 AM
I am located in Massachusetts, on the CT border. I would greatly appreciate any help! I am on the lookout today, going to a few different junkyards in the state that I haven't hit up yet, but most people seem to think it just simply doesn't exist, at least not as an OEM ford product. I might end up just going to a different tranny, though I liked the idea of an "old school" 4 speed. Perhaps just grab a 5 speed out of a newer stang, maybe get somethign decent like the tremec or TKO... or go even more drastic and swap over to an auto, an AOD or C4... Who knows ... I will let you know how my day goes
Bellhousing for 164 tooth flywheel on 400? dogdays 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 1 08-24-2015 03:24 PM
Need 4.0 bellhousing pattern drawing Scot Clutch, Transmission, Differential, Axle & Transfer Case 3 01-30-2015 11:54 AM
bellhousing interchange 302-300 6 390Highboy Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 02-03-2007 06:38 PM
351w bolt pattern(bellhousing) stats2me Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 11-04-2005 09:26 AM
E4OD differences Modular vs. Early blocks abn 1968-2013 Full Size Vans 1 07-30-2004 08:38 PM
Tags
1980, 302, 80, bellhousing, bolt, ford, pattern, size, tranny, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
