Load range D vs. Load range E tires - Ford Truck Enthusiasts Forums
Old 08-25-2004, 09:57 AM
jimh1 jimh1 is offline
jimh1 is starting off with a positive reputation.
It's just about time to replace the tires on the X. I have been considering going to an E rated tire vs the D rated ones I have now. I am a summertime tower with a 32' travel trailer. I thought the E rated tires might be a little more stable when towing. My hesitation is whether the E rated tires will effect the ride quality. The D rated tires I have now do the job just fine, but I thought since it is time to buy anyway, if there is not much difference in ride quality, I might as well get the heavier duty tires.
Any thoughts or suggestions?
Old 08-25-2004, 10:13 AM
jschira's Avatar
jschira jschira is offline
jschira is gaining momentum as a positive member of FTE.
The E's will have stiffer sidewalls and make the rear end a little less squirmy, but if your X tows fine with D's, why not stick with them?
Old 08-25-2004, 11:26 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is offline
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
and you can actually find D's with more load carrying capacity than some E's....
now speed rating is another chapter in the book
Old 08-25-2004, 05:01 PM
Landyot Landyot is offline
Landyot is starting off with a positive reputation.
If you have the original tires, and they're D-rated Firestones, go to your dealer to check on your recall notice. Ford/Firestone will replace all 5 for free, and provide E-rated replacement tires. There's nothing wrong with the original D-rated Firestone tires, except they're just "not enough" tire for the heavy X. Ford tried to skimp on some cost and went with the D's, when the X really needed E's. I kept my D-rated tires at 60PSI at all 4 corners, and they've been fine, with excellent treadwear (72K miles or so & only 3/4 worn). I'm waiting for my local Firestone dealer to come up with the BFG replacements. Meanwhile, I've also gotten some E-rated Nittos on some new rims. I'll probably sell the new replacements after they're received.
Old 08-25-2004, 07:30 PM
smassie88 smassie88 is offline
smassie88 is starting off with a positive reputation.
Be careful, not ALL the Firestone Steeltex D rated were recalled. I have the "R4S" version, Ford/Firestone will not replace them even though they are still only D rated with some cracking on the sidewall near the wheel.
Old 08-25-2004, 07:31 PM
Btravelen's Avatar
Btravelen Btravelen is offline
Btravelen is starting off with a positive reputation.
I put E's on mine at about 38,000 miles, along with heavy duty valve stems. We tow a 31 ft trailer and had a D fail while towing. The valve stem, which I believe was replaced with a marginal light duty rubber unit good for 65 PSI, was what failed, taking the tire with it.
I've seen used Ex's on E Bay and elsewhere that have had C's installed. Future pre-owned buyers beware!
Old 08-27-2004, 07:09 PM
dddenio dddenio is offline
dddenio is starting off with a positive reputation.
If you run 265/75-16 load range E at 55-60psi, you won't notice a difference in ride or handling. E's can be pumped up to 80psi when towing & that makes one heck of a difference. 285/75-16 & bigger sizes have a higher weight capacity in a "D" designated tire. Size does matter!
The ONLY reason I'd run 265/75-16 D's is if I had a gasser motor & or never pulled a trailer. Then D's would be fine.
If you had a 5.4l gasser & never pulled a trailer, C's may possibly be OK. I'd check tire load capacity or just run "D's" and be certain. Anybody know the GVWR w/ a 5.4
Old 08-28-2004, 06:10 AM
jschira's Avatar
Quote:
But you will notice the difference when towing.
My D's have a capacity of 3000 + lbs. each versus 3400 lbs. for an E (265/75/16).
3000 lbs. x 4 = 12,000 load capacity. Not much of a concern to me as my X will never go over above about 9500 lbs. fully loaded. (GVWR is only 9200 lbs.).
Yea, I know, it's not evenly distributed front to rear with a trailer, but that is why I have a WD hitch. The hitch throws a lot of the trailer weight to the front tires.
I pulled 7000 lbs to KC a few weeks ago. The rear tires were only a 5-10 degrees warmer than the front tires (checked with a infrared thermometer).
Old 08-28-2004, 11:28 AM
Jshira, Before I added Hellwig sway bar, The only thing that would improve handling while pulling 29' enclosed trailer was airing tires to 80psi. The D's that were on there stock "aired to the max" were uncomfortable to tow with. E's at 60 psi towed the same as D's at 60psi. For me the E's (80psi) helped a bunch & I wasn't anywhere near loaded capacity. I'll be adding Radius Rods in the near future & I'll report my findings there too.
If someone has D's & never needed more, buy D's. Personally, I NEVER see myself going back to D's. Unloaded my E's are at 55psi & I have the ability to go to 80psi when ever needed. I like options.
Thanks for your input,
Dennis
Old 08-28-2004, 05:11 PM
jschira's Avatar
Yes, that makes sense. E's have an extra 2 plys in the sidewalls, which makes the sidewalls stiffer. I'm sure the E's are less squirmy.
The tires that I wanted only came in D's. I would have gotten E's otherwise.
Old 08-29-2004, 12:36 PM
Gundawg52 Gundawg52 is offline
Gundawg52 is starting off with a positive reputation.
You are probably right that D range tires ride better. I have the Firestone D range and have been pleased with the results as far as wear . They are a bit bumpier in town, but great on the road especially with a load.I have about 30000 on mine presently.
Ken Robinson
Old 08-30-2004, 10:47 AM
amstier amstier is offline
amstier is starting off with a positive reputation.
i switch to michielin ltx m/s e rating and it the ride was incrediable verses the firestone e rating i though i die and went to heaven
Old 09-01-2004, 03:02 PM
XXXcursion XXXcursion is offline
XXXcursion is starting off with a positive reputation.
I have load range E tires and love them compared to the D range.
Much more stable.
Old 09-01-2004, 06:52 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Quote:
You are obviously very happy; do you pull with your truck?
Old 09-01-2004, 06:55 PM
IB Tim's Avatar
Site Administrator
Quote:
Tell me more, is the tire quiet on the open road, OK for most weather????
Does it collect rocks and then pitch them at the fender and innocent folks behind you???
Inquiring minds want to know
LT vs P-rated tires tspangle84 2009 - 2014 F150 46 07-13-2015 09:02 PM
Michelin lts ms2 vs. nitto grapler ? 4rdfvr Excursion - King of SUVs 9 08-30-2011 03:14 PM
Tires and load rating. Chris89lx Ranger & B-Series 8 12-25-2010 08:28 AM
Tire Rating D vs E rating rmrichards949 Excursion - King of SUVs 10 10-17-2010 10:54 PM
Ride quality difference between D series and E series load rated tires? somethingclever 1973 - 1979 F-100 & Larger F-Series Trucks 5 11-23-2009 10:05 AM
Tags
1201160, capacity, difference, firestone, load, range, rated, rating, sale, steel, tech, tire, tires, towing, truck, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
