352 and 390 balancer
Old 08-25-2004, 01:16 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
will a 352 and 390 balancer interchange with each other or not i could not get it to work the 352 is much smaller
Old 08-25-2004, 09:59 PM
Like M. Fords's Avatar
Like M. Fords
Like M. Fords is offline
I know the 360 balancer works for the 390, and I believe the 352 crank is the same as a 360 crank, so they all should interchange. Are you sure you don't have a 351 balancer?
Old 08-26-2004, 12:11 AM
ford390gashog
the balancer is weird the outer ring is a pulley and it is small
Old 08-26-2004, 11:24 AM
BB's Avatar
BB
BB is offline
Does it look like this?
They are fully interchangable.
Old 08-26-2004, 11:53 AM
ford390gashog
yes it does
Old 08-26-2004, 12:48 PM
BB's Avatar
BB
BB is offline
I don't know what the problem is, the hubs are the same size. Maybe it's hanging up on the keyway? Or maybe someone hammered on it and there's a lip on the hub? What exactly is going wrong?
Old 08-28-2004, 06:12 AM
spurredon's Avatar
spurredon
spurredon is offline
From what I have seen they are not all the same. The main difference being the bolt pattern. The 390 outside diameter was also a little bigger as well. I took one off a 390 in attempt to replace the one I had on my 352 which had a stripped hole that secures the pulley. It wasn't even close. I ended up fixing the one that I had by drilling out all three wholes and tapping them to the next size up to keep the balance! Most of the guys that I talked to about this were surprised that they were different but what can I say. I was so sure that they were the same that I drove 20 miles and took one off and brought it home without paying attention to what it looked like since I was so sure it would fit! You can learn something every day!
Old 08-28-2004, 10:36 AM
BB's Avatar
BB
BB is offline
Ok so we're having a problem with the pulley aspect of it?
The hub did fit on the crank end?
Old 08-28-2004, 04:41 PM
ford390gashog
the 390 balancer won't fit at all i don't get it i will try again what kind of installer should i use i know i don't use the bolt to put it on right!
Old 08-28-2004, 04:42 PM
ford390gashog
where did you find that balancer at
hillmstr1
03-12-2016 11:29 AM
candoo
04-01-2015 03:13 PM
big mark
11-11-2004 02:32 PM
Sphynx770
10-27-2004 12:42 PM
L-N-OR
10-13-2004 06:01 PM
Quick Reply: 352 and 390 balancer
