I was wondering what it would take to convert a 360 engine to a 390. From what i understand, they are almost the exact same engine except for the 390 has a crankshaft with a longer throw. So i am assuming that all i would have to do is swap out the crank and maybe install a deeper oil pan and possibly a different oil pump. Is this correct????? Any information would be helpful. Thanks.
All you need to change is the crank, rods and sometimes the pistons. You don't need a deeper oilpan ( unless you just want to increase the oil capacity) or different oil pump.
If they're 360 pistons and in good shape, you dont need to replace 'em. They'll boost your compression ratio on in the 390. Make sure you use 390 rods with 'em or they'll be above deck.
The different sizes are 67-70cc on the D2 and later heads, and 70-74cc on earlier heads. It does make a difference somewhat.
It will definitely make a difference in the ratio.
I ask because I just got my engine back from the shop. It's a 360 from a '71. I had it bored .030 over and 390 crank and rods installed.
I'm a little concerned because the shop put 360 pistons in it, thinking I would want the extra compression. It basically has zero deck clearance. Now I'm sure I'll have to run premium gas, and wondering if that will be enough.
With the right cam, it will run on even 87 octane with 10.25 to 1 compression, my 68 Merc's 390 does.
