'96 Explorer Power Antenna Install
I have a '96 XLT that was originally equipped with a stock radio (non-JBL) and standard antenna. I put an Alpine head unit in and bought a power antenna from Ford. When I went to put the antenna in, I noticed it says not to hook it up directly to a power source. The antenna cable goes to the back of the head unit, but I have two other cables I don't know what to do with. (1: green/yellow 2: red) I thought one was power, and the other was ground. Has anyone done this install? If so, how? I was told I might need a power antenna module from an Explorer with a JBL system just to use it. Is this true? Any help is appreciated.
Guest
Posts: n/a
Most aftermarket radios have a wire for the power antenna check your wireing harness on the alpine head unit to check...
Kris
>so, how? I was told
> Is this true? Any
Kris
>so, how? I was told
> Is this true? Any
Guest
Posts: n/a
u want to replace the factory CD unit
did anyone knows the size is fit right in to it ..i mean i don't want to leave any space in that space
i don't know what size (1DIN ,1.5DIN,or2DIN.)
can anyone can solve the problem to me
and did u know what brand they carry the stero is fit in there,i don't like to put a 1DIN in it.
ojh
03-01-2017 04:36 PM
Cowman79
12-07-2012 02:05 PM
kevin74656
01-11-2007 11:02 PM
