Whats up with fusible links? - Ford Truck Enthusiasts Forums
Old 08-24-2004, 01:01 PM
wingcommander wingcommander is offline
wingcommander is starting off with a positive reputation.
I managed to burn a link on the exhaust( a whole other story). It is the plastic one for the charging system and now my battery does not get charged nor does my guage work. I am afraid to bypass. Cant find one at parts store. Is this a replace a whole wire bundle thing?
Old 08-24-2004, 01:34 PM
sjwoody sjwoody is offline
sjwoody is starting off with a positive reputation.
I've no experience with fusible links, but my Haynes manual describes a repair. Basically it's the same as a normal wire splice. I've seen fusible links for sale at the auto parts store near me...you might have to look around a bit to find what you need. I wouldn't think you'd need to replace a whole bundle for a bad fusible link. Their function is just like a fuse and should be about as easy to replace. My understanding is that there are different size links for different amperage capacities. Make sure you have the right size. Good luck!
Old 08-24-2004, 01:55 PM
thanks
Great news will do.
Old 08-24-2004, 06:51 PM
JerrySimm JerrySimm is offline
JerrySimm is starting off with a positive reputation.
It would be best to solder the wires and cover them with heat shrink tubing if you can when you replace them. That will help to prevent future corrosion and subseqeunt resistance heating in the wire.
Old 08-24-2004, 07:35 PM
Opera House Works Opera House Works is offline
Opera House Works is starting off with a positive reputation.
That may be easier said than done. I'm not sure if the metal the link is made of can be soldered to. The main design of these links is to have a smaller diameter wire that will fuse open first with a high temperature insulation that won't melt through. You could just splice in a short section of wire that is a couple gauges higher and cover that with some rubberized fiberglass spaghetti for burn through protection.
Old 08-24-2004, 10:48 PM
Big Jim M Big Jim M is offline
Big Jim M is new and has a neutral reputation at this point.
Smile I've never had one that burnt for a reason!
All of the ones I have seen burned up have been as you say, from the exhaust or some other stupid problem that should not have been!
I just cut them out and replace them with a known good enough wire for the amps needed. I think they are mostly for some extreeme rare happenings. Anyway that is what insurence is for.
Big Jim
Old 08-25-2004, 07:01 AM
jwirth jwirth is offline
jwirth is starting off with a positive reputation.
Couldn't you just splice in a generic fuse holder if you are worried about circuit protection? Would have to be heavy enough.
Old 08-25-2004, 08:47 AM
Splicing in a regular fuse might work...I don't really know. However, years down the road if you have a problem in that circuit, you (or whoever you sold the vehicle to) might have a hard time troubleshooting without the original components in place. Just my opinion, but restoring things to original condition and securing the bundle away from the exhaust would be the best bet in the long run.
By the way, after referring back to the Haynes manual, they also suggest soldering the splice and protecting with tape or heat shrink. Apparantly soldering can be done on the fusible links.
Charging System Fusible Links - where are they? Harley Monster 1999 to 2016 Super Duty 16 02-04-2017 07:09 PM
new alternator not charging pyroracing85 Ranger & B-Series 14 10-14-2016 06:48 PM
2001 F350 diesel v8 7.3L Dually--location of fusible links running from alternator Glide2277 1999 to 2016 Super Duty 3 11-11-2013 07:51 PM
Starter/Charging system schematic PowerstrokeRyan 1994.5 - 1997 7.3L Power Stroke Diesel 3 04-24-2011 07:36 AM
Charging system Pocca Electrical Systems/Wiring 9 07-25-2007 01:31 PM
Tags
2001, 2004, 91, bad, excursion, explorer, f150, ford, fusible, link, links, location, moutaineer, soldering, sport
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
