Compass / Temp
Old 08-22-2004, 09:32 PM
Pete Johnson's Avatar
Pete Johnson
Pete Johnson is offline
Compass / Temp
2002, 4.0 Auto 4x4, 4 door, 87k. The compass will only read N, or E, Have tryed the book recomended reset. No luck. Temp read's within 1 or 2 of actual.
Old 08-23-2004, 09:44 AM
jonm61's Avatar
jonm61
jonm61 is offline
Try disconnecting the battery for 20-30 min. When you reconnect the neg cable, the system will reset & have to be recalibrated. Other than that, locate your temp sensor, near the left headlight, make sure its there, intact, and still mounted. If it looks ok, then take it in for service.
Old 08-24-2004, 10:31 AM
Pete Johnson
Compass / Temp
Tryed the 30 min. disconect, Did the reset /calibration, no luck, still reads N or NE. Any idea on what the temp unit look's like ( need a clue as to size, shape, or color. ) No book, no idea what I'm looking for. .
Old 08-24-2004, 12:54 PM
91-Exploder's Avatar
91-Exploder
91-Exploder is offline
It looks like a short cigar and is mounted behind the bumper under the drivers side headlamp it has two blue leads one with a yellow stripe
Old 08-24-2004, 06:46 PM
JerrySimm's Avatar
JerrySimm
JerrySimm is offline
I don't know where the geomagnetic sensor is, it may be a circuit in the PCM, but is there any chance of having something near the sensor that's emitting a magnetic field. A constant magnetic field near the compass could override the earth's geomagnetic potential and lock the compass in one direction.
Old 08-25-2004, 06:42 AM
91-Exploder
The geomagnetic sensor or "Flux Gate" is located in the console itself so if your kid has stashed a magnet in the door opener compartment that could be the cause of your problems. Otherwise you will need a new console they are reasonably priced on ebay and if you really need one send me a private message as I have at least one spare.
mikereidjr
Ford Truck Parts for Sale
01-12-2017 09:34 AM
DieselDenny
6.4L Power Stroke Diesel
12-13-2016 05:35 PM
willydad
1997 - 2003 F150
12-09-2016 04:42 AM
pukemon
2004 - 2008 F150
33
09-12-2009 05:35 AM
maldb2
1997-2006 Expedition & Navigator
08-09-2003 12:04 PM
Quick Reply: Compass / Temp
