Compass / Temp - Ford Truck Enthusiasts Forums
Compass / Temp
Old 08-22-2004, 10:32 PM
Pete Johnson Pete Johnson is offline
Pete Johnson is starting off with a positive reputation.
Compass / Temp
2002, 4.0 Auto 4x4, 4 door, 87k. The compass will only read N, or E, Have tryed the book recomended reset. No luck. Temp read's within 1 or 2 of actual.
Old 08-23-2004, 10:44 AM
jonm61 jonm61 is offline
jonm61 is starting off with a positive reputation.
Try disconnecting the battery for 20-30 min. When you reconnect the neg cable, the system will reset & have to be recalibrated. Other than that, locate your temp sensor, near the left headlight, make sure its there, intact, and still mounted. If it looks ok, then take it in for service.
Old 08-24-2004, 11:31 AM
Compass / Temp
Tryed the 30 min. disconect, Did the reset /calibration, no luck, still reads N or NE. Any idea on what the temp unit look's like ( need a clue as to size, shape, or color. ) No book, no idea what I'm looking for. .
Old 08-24-2004, 01:54 PM
91-Exploder 91-Exploder is offline
91-Exploder is starting off with a positive reputation.
It looks like a short cigar and is mounted behind the bumper under the drivers side headlamp it has two blue leads one with a yellow stripe
Old 08-24-2004, 07:46 PM
JerrySimm JerrySimm is offline
JerrySimm is starting off with a positive reputation.
I don't know where the geomagnetic sensor is, it may be a circuit in the PCM, but is there any chance of having something near the sensor that's emitting a magnetic field. A constant magnetic field near the compass could override the earth's geomagnetic potential and lock the compass in one direction.
Old 08-25-2004, 07:42 AM
The geomagnetic sensor or "Flux Gate" is located in the console itself so if your kid has stashed a magnet in the door opener compartment that could be the cause of your problems. Otherwise you will need a new console they are reasonably priced on ebay and if you really need one send me a private message as I have at least one spare.
Overhead Compass and Temp Quit Working kailor 1997-2006 Expedition & Navigator 43 01-20-2017 04:58 PM
Auto Dim Mirror mikereidjr Ford Truck Parts for Sale 4 01-12-2017 10:34 AM
Rear view mirror, no compass or camera DieselDenny 6.4L Power Stroke Diesel 10 12-13-2016 06:35 PM
compass/outside temp--1999 F150 4.6 willydad 1997 - 2003 F150 1 12-09-2016 05:42 AM
Compass/ Thermostat Biggg72 1997-2006 Expedition & Navigator 2 09-30-2008 12:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
