Quick Poll (Yes/No) Do you have steering wheel shimmy?
Hello,
Sorry if this has been beaten to death, but regarding the steering wheel shimmy on 2004's I have the option of returning this truck to the dealer next week and getting my trade-in allowance back. Trying to catch up on all the previous treads on this issue is a daunting task. I have a real delima on my hands.
I just blindly walked into the whole issue (Including the Tech Service Bulletin 03-20-8) on steering wheel vibrating which many people are reporting. I have to make a quick decision as to what I want to do regarding the return of the vehicle or not.
Can I have a show of hands (yes/no or an explanation, fix,etc) if you are having steering wheel shimmy and if you run OE tires and wheels or not.
I had a wheel and tire set put on immediately after I took delivery of this truck (which only complicates things) so I don't know if I had this problem or not prior to the wheel/tire set. Discount Tire has tried 3 different sets of tires on my 200 mile truck now and I have shimmy on all of them. 3 different sizes at that. 285/50, 275/55, and now I have 265/50-20 Falkons which look real nice. They are almost dead-on vs the overall rolling diameter and have an aggressive enough look for me. They have a very reasonable width which the dealership could not argue with as well since the OE's are 255/65-17's.
I was really wondering if the problem was a bad aftermarket wheel during these 3 balancing attempts, the whole time not knowing the vehicle itself had issues. I have to say that other new 2004 F-150's I test drove had way too much steering wheel feedback even with OE tires/wheels.
I need to hear from you 04 owners! Even if it is yes or no.
Thanks in advance,
Reid in Houston
Thanks in advance,
Reid in Houston
I have 20" aftermarket wheels that are hub-centric and I have wheel shimmy between 60 and 70 in one wheel/tire combination that's been rebalanced 5 times. Didn't happen when I first had the package put on- only started after the dealer rotated my tires as part of routine maintenance. One issue is that my wheels are designed in such a way that they can only be balanced using tape-on weights (no outer rim to attach to). Anyway, I'd definitely factor that into my next wheel selection because I've never trusted tape-on weights.
I had "0" shimmy for the first 3k with my stock wheels/tires. If the first rotation on my 20's hadn't been so smooth, I'd wonder if there isn't something mechanical on the truck's steering that can't handle the wider wheels/tires (since a lot of folks with aftermarket wheels seem to be having this issue).
