Will Power Stroke have an answer for Cummings soon? - Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Old 08-22-2004, 01:40 AM
VintageRR VintageRR is offline
VintageRR is starting off with a positive reputation.
I've seen trucks with Cummings power run under 12 seconds, but nothing with a Power Stroke. Will Ford have a performance answer anytime soon?
Old 08-22-2004, 04:24 AM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
Do you mean Cummins out runs the powerstroke. Ive never seen that one before. Powerstroke is usually dominate on the race track. I havent seen a cummins take one yet. Fill me in with some more info.
Old 08-22-2004, 11:21 AM
Ratsmoker's Avatar
Ratsmoker Ratsmoker is offline
Ratsmoker is starting off with a positive reputation.
All three companies make engines that have available mods to get into the 12s. I have seen all three of them do it personally.
Thread moved to proper forum.
Old 08-22-2004, 11:23 AM
johnsdiesel's Avatar
johnsdiesel johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
The PSD already outruns the Cummins. Before you start flaming make sure you know what you're talking about. There's no such thing as a "Cummings" diesel.
Old 08-22-2004, 09:24 PM
IB Tim's Avatar
IB Tim IB Tim is online now
Site Administrator
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
Where in the world did this thread start...the first time
Old 08-22-2004, 10:42 PM
12s? I'm talking about 11s. The 11.42 F350 vid going around is of a cummins powered Ford. I hear there are not enough aftermarket 6.0L parts to make 700+ hp.
Old 08-22-2004, 10:52 PM
Quote:
PSD outruns Cummins in stock trim.
If there is any flame here it was in the direction of Dodge... don't you get it?
Look. The fastest 1/4 run I've seen by a CC full size truck was a F350. Thing is, it is Cummins (ok for you?) powered F350.
I've been told that max PSD hp is around 500 hp with available mods and 800 in the Cummins with available mods. Prove me wrong.
Old 08-22-2004, 10:55 PM
Logical Heritic Logical Heritic is offline
Logical Heritic is new and has a neutral reputation at this point.
Didnt matt tomac burn an 11.99 with his dmax?
Old 08-22-2004, 11:00 PM
Quote:
The cummins has made around 800 without the assistance of drugs. A dmax can get close with drugs. 745 with nos ats? I dont think there is a PSD in the ballpark. Drugs or no. Maddog just got 850 or so, on the juice, before he blew a boot. He thought it was easily a 900 hp run. Maybe even close to 1000.
The dynos clip him at 1500lb ft though. I dont think they are doing any math above 1500 cause they cant measure that much torque. So its robbing his hp if Im correct. With that kind of hp I think he must be making 1600-1700 lb ft. Ive been wrong before so dont quote me.
Old 08-22-2004, 11:03 PM
Quote:
That being said, is there anything on the horizon for the PSD?
Old 08-22-2004, 11:09 PM
Yes. I think the 6.0 will be much more mod friendly than the 7.3. Plus they just got the injectors figured out. Im not sure how much of that randd will translate over to these new injectors but it was a long road to discovery. My hopes lie on the 6.0 for big power. The 7.3 always had a problem getting enough fuel into the cylinder. Then you need to be able to hold a lot of boost. Boost is the secret killer. Im suprised the cummins are withstanding over 100lbs but 7 mains will help distribute that huge load. Anyone want to do the tdc pressure per square inch a 16.5 to 1 at 100lbs boost. Remember air expands when it gets hot. What temp is necessary to ignite the fuel?
Old 08-22-2004, 11:23 PM
Mine too. I'd like to run around 500 hp after my new King Ranch is broken in.
Old 08-23-2004, 12:20 PM
DMAX-HD's Avatar
DMAX-HD DMAX-HD is offline
DMAX-HD is starting off with a positive reputation.
Last I seen on the Chevy board it was 11.69
Old 08-23-2004, 02:00 PM
FORD352V8 FORD352V8 is offline
FORD352V8 is starting off with a positive reputation.
This sounds like antoher TROLL.
Old 08-23-2004, 09:22 PM
valenrandy's Avatar
valenrandy valenrandy is offline
valenrandy is starting off with a positive reputation.
didnt someone post a video somewhere around here showing an f350 doing 11.42 in the qtr mile? I downloaded the video and boy did that truck smoke like it was on steroids or something...
Tags
cummings, fords, powered
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
