Will Power Stroke have an answer for Cummings soon?
#47
Originally Posted by Logical Heritic
Like I said before. It is doubtful that you would ever have to change the leaf springs due to failure. You might change them out if you bought the truck specifically for hardcore 4x4ing and wanted to lift it and do other 4x4 mods.
#48
Originally Posted by tmyers
Its also doubtful that a coil spring would ever fail also. Ford is using basically the same design that is used in monster trucks. Would you call them weak? I think this new system will provide better strength than a leaf spring system. Couple that with easy to swap springs for different performance requirements and I'll bet that everyone is using this in the future. Now if I can figure out how to mod the 77 with this I'll be in heaven.
You are excluding the track bar in your fewer parts. I get 4 bushings per side for the control arms. 2 for the track bar. A leaf keeps the axle very located. Much better than a slinky ever could.
#49
This is an invalid argument. To me it sounds about the same as saying IFS on Chevy is better because it is used on Baja Pre-Runners and 4-wheel Independent suspension is better because it is used by HUMMER. No, I do not believe the monster truck coil springs are weak(they jump about 20 feet high they better be strong) but then again how long does the average monster truck last. They are not meant for longevity. I do not feel that IFS is a detrimental aspect... neither do I feel that coil springs are a severe disadvantage. Some people just don't like change... why not go with the tried and true. Leaf springs are older than time and have so far shown themselves to be a steadfast design. I usually prefer the older, simpler technology on automobiles but I do not oppose the coil springs.
Trivia Question: What was the first vehicle to use 4-wheel disc brakes?
#50
One of my friends (Dougie Diesel) has a pick up that runs in the low 9s.
Chevy P/U with a 6V53 Detroit. twin turbos feeding the blower, 58LBS of boost at the intake. Alcohol / water injection into the turbos. Runs 1/2 diesel fuel and 1/2 auto trans fluid (to keep the injectors from locking in full fuel). Allison auto and shifting at 5000 RPM.
All this and he did it 1982
He is now in the prosess of building a funny truck. Diesel powered. He says it will run in the 7s
#56
Originally Posted by Bordaine
Trivia Question: What was the first vehicle to use 4-wheel disc brakes? First vehicle with 4 wheel disc brake was a Tucker
#58
#60
What was the best car of that time and who knows enough to do a comparison of the two.
It might not parallel exactly what this forum is about, but it is close and would be informative to take a step back in time and a look at vehicles then. There is no doubt in my mind that many of today’s thoughts/ideas are a byproduct of yesteryear.
