Reprogramming Codes
Reprogramming Codes
Im sure the owners manual will describe all those functions , if not your local Ford Dealer should be able to help . Its doubtful youll find any info here because the possibilitiy exists that someone with a stolen vehicle or its equpiment may be looking for the info you have asked for , Not saying thats the case with your question , but its always a possibility .
Reprogramming Codes
The owners manual for your truck has all the instructions on how to add a door lock code, and alter some radio settings. To modify lock codes and features, you do need to know your original 5 digit code which came with the truck on a plastic card. The instructions are very easy to follow, good luck.
Reprogramming Codes
According to the owner's guide, to reprogram transmitters, you have to place the key in the ignition ans switch from OFF to ON five times in rapid succession (within 10 seconds). After the doors lock/unlock, press any button on all transmitters (up to four). When completed, switch the ignition to OFF. All transmitters must be programmed at the same time. Good luck.
99 7.3 towrig
04-24-2008 06:34 PM
