Spark Plug Firing Sequence for 88 Bronco II - Ford Truck Enthusiasts Forums
Old 08-20-2004, 07:59 PM
DavJRee DavJRee is offline
DavJRee is starting off with a positive reputation.
Question Spark Plug Firing Sequence for 88 Bronco II
I have an 88 Bronco II with the 2.9 L V6. I replaced the plug wires today, and I think I may have messed two of them up. Can anyone give me the firing order of the cylinders and the distributor? I'll also need to know which cylinder is considered #1, and how the numbering goes. I'm guessing #1 in the one on the left, closest to the firewall, but I want to make sure.
Thanks for any help anyone can give me.
David
Old 08-20-2004, 09:57 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
2.8L and 2.9L engines Firing order: 1-4-2-5-3-6 distributor rotation: clockwise
#1 is the front passenger side plug. Working toward the firewall on the passenger side you have 1-2-3 cylinders.
From the front drivers side to the drivers side firewall you have cylinders 4-5-6
8 Bolt Differential Cover for '62 Econoline elmcity88 Ranchero & 1961 - 1967 Econoline 2 08-11-2011 02:00 PM
EGR Vacuum Soleniod nelly781 1978 - 1996 Big Bronco 3 12-18-2007 04:42 AM
89 Bronco II Towing spazzbear Bronco II 5 04-09-2003 03:36 PM
Firing order mikeh Bronco II 2 12-13-1999 05:23 PM
Tags
1988, 29, 88, bronco, diagram, fireing, firing, ford, ii, litre, order, plug, plugs, spark, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
