Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-19-2004, 11:33 PM
FTK560 FTK560 is offline
Garage is empty, add now
FTK560 is starting off with a positive reputation.
Exclamation Acceleration problems
This is my second ford ranger, I just got a 1988 Ranger 2.9 auto for my wife. The problem I'm having is a bog down in mid acceleration. If you push harder on the throttle it picks up and runs fine. It doesn't miss it just bogs down. It does this on take off at times and at a steady cruising speed, it just comes out of nowhere and bogs down. I've changed the coolant temperature sensor, air filter, fuel filter, cleaned the throttle body, and changed plugs. There is no engine light coming on, and the fuel pressure is fine. I have no idea what to look for next. Please help me with some ideas. Thanks in advance.
  #2 (permalink)
Old 08-20-2004, 01:43 PM
Vin 95 Vin 95 is offline
Vin 95 is starting off with a positive reputation.
Take it to auto zone and they will read the codes for free,the light does'nt have to be on for it to have pending codes.this is a good place to start.it sounds like you have an intermitant problem,coming and going.maybe you can find it before it goes out for good.however it may be something very simple.with these trucks it usually is.you say the fuel pressure is fine,did you try unpluging the vaccum hose to the pressure regulator with the truck running and see if the pressure came up by about 10psi ? and is there gas being sucked into the vaccum hose to the regulator?
  #3 (permalink)
Old 08-20-2004, 10:08 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE!
This Ranger being new to you should get a new fuel filter, just because, like all the other little things.
AL.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
Tags
1963, acceleration, ford, problems
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
