Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-19-2004, 08:49 PM
Curious97Ranger Curious97Ranger is offline
Garage is empty, add now
Curious97Ranger is starting off with a positive reputation.
97' 4 Banger 2.3L Cold start problems
Granted in the mornings it's only about 60 degrees outside this time of year....but my truck has ALWAYS started right up. Now...it takes a couple tries to do so. Engine turns over just fine, but won't run on first try. Same goes for in the afternoon after sitting at work for 8 hrs. and it's 90 degrees outside. What could be the possible problems?
I just recently had the spark plugs and wires replaced, in hopes that that might help. Also had the fuel cooling sensor AND the cooling system sensors replaced, along with the fuel filter.
Aside from that, the check engine light's been on for a couple years....knowing it was the EVAP system. I did NOT replace the whole assembly. Only what I believe to be the sensor part # F57Z-14A606-BA. Refer to thread http://www.ford-trucks.com/forums/s...threadid=152825 and the diagram "figure 2". There are 2 parts in that diagram, the one on the left is what I replaced. Disconnected the neg. battery cable for a half hour to reset the codes and now the check engine light stays off.
My question is this...could the other part (what I gather to be the actual fuel canister valve) be the cause of why the truck won't "cold" start. I doubt it...because the check engine light would be back on, which it has stayed off for 250 miles now. Btw...my truck has 150,000 miles on it. It's a 2.3L engine as it says in the title.
Any help would be greatly appreciated.
  #2 (permalink)
Old 08-19-2004, 09:00 PM
Dealford's Avatar
Dealford Dealford is offline
Dealford is gaining momentum as a positive member of FTE.
Welcome to FTE!
You may want to have the codes pulled again.
Try taking the vacuum line off the fuel pressure regulator to see if it is wet inside or smells of gas.
The Haynes service manual is worth the $15. Mine has paid for itself many times over!.
AL.
__________________
97 Ranger (metric half ton) 2.3,5spd. Saphire blue metalic w/matching cap & Stock Rims 4 winter.
92 Town Car....Sweet PITA.
90 BII 4x4 Ongoing Project, aka PITA
63 Fairlane, Gone to my buddy Chuck.
It Aint Fun Unless It's Done The Hard Way!
  #3 (permalink)
Old 08-20-2004, 02:19 PM
Vin 95 Vin 95 is offline
Vin 95 is starting off with a positive reputation.
Could be a sticking fuel pump relay. in the under hood fuse box there are several 1 in. square relays.the cover to the box should show the location of the pump relay.when it wont start,try tapping on it a few times then try to start it.
  #4 (permalink)
Old 08-22-2004, 06:57 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
Simple test for a weak fuel pump: Turn the key to run for 2 seconds then off. Do that 6 times to build fuel pressure then see how it starts.
Tags
23, 23l, 97, banger, cold, f57z14a606ba, ford, problems, ranger, reason, start, starting, troubleshooting, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
