'67 F100 - No headlights, turn signals
'67 F100 I just picked up . . .
Here's what electrical items work: engine, windshield wipers, radio, heater, rear running lights, back up lights, temp guage, and speedo light (sorta, bad rheostat).
Here's what electrical items do not work: head lights, turn signals, brake lights, and front running lights.
Any ideas? All the fuses are good. I hear clicking noises under the dash. ????
How about highbeam headlights?
Change the signal flasher just `cause they're cheap & do fail sometimes.
Pull the headlight switch & check the wiring plug for any signs of burnt or over heated wires. Use a test light to see if you are getting power to the plug. You may need to change the headlight switch also.
Changing the highbeam switch on the floor with a new one from Ford is a good idea. And, yes they are better than the aftermarket switches.
AL.
AL.
For the brake lights, check for voltage at the brake switch. One side should be hot, the other side should be hot when the pedal is pushed. If this all checks out, the next spot the brake signal goes to is the turnsignal switch. The power from the brakelight switch goes into the turnsignal switch, as does the flasher power. The turnsignal switch co-ordinates the brake signal and the flasher signal, since the rear turn and brake lights use the same filament in the rear bulbs.
You're right on, Al. I stomped the high beam switch several times and now the headlights come on low beam. And played and wiggled with the headlight switch and can get the parking lights to come on at the first detent but not the second with the headlights. The dash dimmer is completely worn. So two new parts there.
Awesome info, Dave. The brake switch must not be getting any power and thus the others down the line aren't getting it either. I think I saw that brake switch in the driver's side frame rail attached to a proportioning valve or y-block, right? Good place for a wire to come loose or get caught in something. When it gets light out again I'll go after it...
Thanks! You guys know these trucks.
What color are the wires going to the stop switch? I don't have a diagram for your truck, but I am looking at one that may be close to it and it has a lightgreen/red feeding the switch, and a lightgreen leaving the switch going to the turnsignal switch.
The lightgreen/red wire that feeds the switch comes from a 15 amp fuse in the fuse box.
The two wires on the stop switch are red (constant 12v) and red w/black stripe (goes to brake lamps).
I verified this with an ohmmeter by checking the red/black wire with and without the rear bulbs plugged in. My problem is that red has no power, ever, no matter what. Going through old posts I'm starting to believe that the brake switch gets its power from the turn signal switch, right?
Yep, you're exactly right. The flat part should have been a give away but I was afraid to start twisting without asking one of you guys. Okay . . . now for the magic question: where are the flashers in this thing???? I'm looking everywhere for the little cylindrical flashers like all my other cars and haven't found 'em. In a '67 is the flasher that big square thing mounted with two bolts behind a dash support? I see two wires going in and two going out. Is that it? I guess I could go jumper it and see if my hazards or directionals come on . . . I'll be back
67's should have the small metal or plastic cans floating around under there somewhere. You might find just a plug under there where it's supposed to go. That would explain why they don't work. Go up to the old truck forum and see if any of those guys with your year truck can tell you where it's supposed to be.
