94 Explorer Keyless Remote Receiver Location
I have a 94 Explorer Eddie Baurer Edition. I was told that the receiver for the keyless remote is back in the jack compartment. What exactly would I be looking for. I see a black box and on the bottom is a white button that when I press it a red light comes on. Is it the receiver? I bought the truck used and they didn't have any remotes for it. I am assuming that it has keyless entry only because it is an Eddie Baurer. What would it look like and how would I program it myself. Thanks for the help.
Josh
Josh
You can buy new keyless entry FOBs in ebay for about $10 to 20 each, complete with instructions.
Someone posted the following here about explorer keyless:
"According to the owner's guide, to reprogram transmitters, you have to place the key in the ignition ans switch from OFF to ON five times in rapid succession (within 10 seconds). After the doors lock/unlock, press any button on all transmitters (up to four). When completed, switch the ignition to OFF. All transmitters must be programmed at the same time. Good luck."
use the "search feature" on this page and look for "keyless"
good luck
good luck
'94 Explorer Remote Keyless Entry Help
I have a 94 Explorer LTD Edition. Which module in the jack compartment is the rke one? I see a black box and on the bottom is a white button that when I press it a red light comes on. Is it the receiver? I bought the truck used and they didn't have any remotes for it. I have a remote that should work but the key cycling doesnt do it, Can I reset it from the module itself and/or test the module? I have seen something about jumping terminals on the plug or module but not specific info. My ignition switch is a little flaky/worn so not sure if that is not letting the locks reset. Thanks for the help
The first gen Explorers will not program by using the key flipping method. There is a programming connection in the jack compartment that has two pins. Those two pins have to be jumped (bridged) by a piece of metal. I used a paperclip. When that happens the door locks will cycle indicating you are in programming mode, you then press ALL the buttons on the remote in any order and you are done. QED. I think I have one for sale if you need one. Hope that helps, Eric
'94 Explorer remote fixed!
I found this entry in another forum...IT WORKED
It's easy to reprogram your X's. First make sure you have the Remote Keyless Entry (RKE) sending unit. Open the jack storage compartment on the driver's side of the cargo area. Look into the compartment and up and toward the front your truck. If you see a silver metal box, you're in luck! Now look for the "programming connector" (two quick-connect receptacle type connectors encased in a black or grey plastic case about the size of the tip of one your fingers). It will be hiding with the tail light connectors on the left of the windshield washer fluid reservoir with nothing connected to it. Turn your ignition to ON or accessories and stick a open, V-shaped paper clip into the metal connectors to momentarily short them together. You will see (and hear) your locks cycle. Now just press a button on your key fob (the signal is recorded or "programmed") Good Luck!
The service manual indicates the Remote Keyless Entry (RKE) module is located on the driver's side rear quarter panel. I've not owned a 1994, the oldest I had was a 1999. If I recall correctly though, the 1999 also had the RKE module mounted in the left rear of the cargo area. The module was mounted pretty much above the driver's rear wheel well, behind the plastic panel in the cargo area. There was an access panel that had to be removed, then using a flashlight I could look towards the front of the vehicle and see the RKE module.
-Rod
-Rod
The following image should make it a bit clearer where the module and programming connector is located.
Location of RKE module on 1994 Explorer
From the factory service manual:
To program (or re-program) transmitter(s) into the remote entry receiver module, perform the following steps:
1. Turn ignition switch to ON or ON/ACCESSORY position and momentarily short the two terminals of the Program Connector (J4) (a two-pin connector taped to the wire assembly and accessed by removing the LH quarter access panel). All doors should lock then unlock. Remove shorting pin.
2. Press any button on transmitter. All doors should lock then unlock to verify the transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same transmitter). If door locks still fail to respond, go to «Pinpoint Test F» .
3. Repeat Step 2 to program additional transmitters into the remote entry receiver module (up to four transmitters maximum).
4. Turn ignition switch off. All doors should lock then unlock.
5. Check operation.
5. Check operation.
yvonnemcav
02-27-2002 08:43 AM
jkassab
11-17-2000 05:47 PM
jkassab
Electrical Systems/Wiring
11-17-2000 03:03 PM
