2WD Lift Kit for 1979 F150 - Ford Truck Enthusiasts Forums
Old 08-19-2004, 02:04 PM
jdency's Avatar
jdency jdency is offline
jdency is starting off with a positive reputation.
I'm Looking for a 6" to 8" suspension lift for a 1979 Ford F150 2wd. I put one on my 82 F100 using BDS and superlift parts. However I can not locate a manufacturer for a 2wd lift for a 1979. I would appreciate any help. Thank you.
Big Mt. John
Old 08-19-2004, 04:02 PM
supercab4x4dually's Avatar
supercab4x4dually supercab4x4dually is offline
supercab4x4dually is starting off with a positive reputation.
Jeff's Bronco graveyard.
Old 08-19-2004, 05:39 PM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
I have posted this before, but nobody seems to know a whole lot about it. It is an Ibeam flip. Here's a pic
http://www.ford-trucks.com/user_gall...=18635&width=2
Old 08-21-2004, 12:54 AM
bajascott bajascott is offline
bajascott is starting off with a positive reputation.
i did mine its a 77 f150 2wd. 6"national coils, and i bent the beams myself. extended the radius arms and corrected my castor . drive straight . check autofab.com he specializes in king pin suspension
Old 08-21-2004, 06:35 AM
teds74ford's Avatar
How did you bend the beams? With a sledge? I watched junkyard mega wars and they had a 2wd ford that the guys flipped the beams on, but then the tires really tipped bad. Ted
Old 08-21-2004, 10:51 AM
i used a set of anchors in my buddys shop, they were chains in the concrete and a port-o-power with some heat . most would use a press but i am cheap and dont have a press that it powerfull enough.
1979 Ford 1/2 Ton Lift caleballen95 1973 - 1979 F-100 & Larger F-Series Trucks 1 01-24-2015 10:22 PM
Ford 300i6 perches 1979 f150 4wd (same as FE) julcan92 WTB - Parts & other 3 05-18-2014 10:08 PM
1977 F-350 2WD body swap with 1979 F-250 4WD retiredsquid 1973 - 1979 F-100 & Larger F-Series Trucks 0 06-23-2013 10:41 AM
Another Steering Box 1979FordDiesel 1973 - 1979 F-100 & Larger F-Series Trucks 3 06-06-2013 08:30 AM
Haynes or Chilton Manual?? 79F150Seattle 1973 - 1979 F-100 & Larger F-Series Trucks 20 07-15-2012 12:25 PM
Tags
1979, 2wd, 77, 79, 82, a1979, drive, f150, f250, ford, kit, kits, lift, suspension, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
