93 explorer with no heat
First off check the engine coolant quantity . Does the engine temp come up somewhere in the Normal range ? When was the last time the cooling system was serviced ? Any interior coolant leaks ? Its possible the heater core is clogged , but you need to also check to make sure the engine is warming the coolant to a temp where the interior will be warmed .
Guys i dont drive this truck the wife does. she has a bad habit of telling me of problems months after they occur. when they become critical. It comes up to tempature. The coolant is full
with new mix. i replaced the heads this summer when it started to use coolant. im leaning towards a blocked heater core. the hose to the core is very warm where the hose from the core is cold. i checked the routing of each hose and they are correct.
Thanks
garbz
Thanks
garbz
garbz2
30
03-06-2015 02:18 AM
craziejoker
04-16-2014 06:10 PM
