Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-15-2000, 04:04 PM
ted ted is offline
ted is starting off with a positive reputation.
96 4wd m/t I AM EXPERIENCING A STALL AND/OR STUMBLE DURING A COLD ENGINE
Does anyone know how to access a technical service bulletin? I found my problem on the NHTSA's web site and now I would like to know how to fix it. I love my truck but this stalling problem has got to go. It only happens when the engine is cold and sometimes I can catch it before it fully stalls. The tsb's are as follows:
Service Bulletin Number: BC4943960601
Bulletin Sequence Number: 12
Date of Bulletin: 9606
NHTSA Item Number: SB047890
Make: FORD TRUCK
Model: EXPLORER
Year: 1996
Component: FUEL: THROTTLE LINKAGES AND CONTROL
Summary: 96 EXPLORER 4.0L MANUAL TRANSMISSION WILL STALL WITHOUT A CODE, 95-96 RANGER
4.0L MANUAL TRANSMISSION, WILL STALL AND CODE P1506 WILL BE PRESENT.
Service Bulletin Number: 98610
Bulletin Sequence Number: 134
Date of Bulletin: 9803
NHTSA Item Number: SB601321
Make: FORD TRUCK
Model: EXPLORER
Year: 1996
Component: FUEL:THROTTLE LINKAGES AND CONTROL
Summary: SOME VEHICLES MAY EXPERIENCE A STALL AND/OR STUMBLE DURING A COLD ENGINE
DECEL. *YC
Any help that you could provide would be greatly appreciated. Thank you very much. -Ted
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-15-2000, 09:01 PM
drew22 is starting off with a positive reputation.
You might want to post your message on www.4x4central.com They dedicated to explorer and the odds are that someone there might be able to help you. I have a 96' 4.0L V6 4x4 explorer and I a problem with the engine stalling too. If you find out how to fix this, please post your results. Sorry I could not be of any more help.
Good luck,
Drew
  #3 (permalink)
Old 06-16-2000, 10:04 AM
PAUL_2 is starting off with a positive reputation.
Ted ,
Simply take the info you have to your local Ford dealer and ask either a competent tech or a service person what the resolution to the TSB's are for Explorer . They simply type the info into their OASIS System and the info will be presented to you . At that point either they can repair the problem , if its a recall they will fix it at no cost to you . If its a TSB they will fix it , perhaps if you discuss the problem with the service manager and ask if Ford will split the cost of repairs and parts with you esp if this has been an ongoing problem that you and your local Ford dealer have dealt with before .
Paul
  #4 (permalink)
Old 12-14-2000, 11:05 AM
viper is starting off with a positive reputation.
Ted,
This problem could be tied in with the intake mainfold gasket and the cam tenioners. There currently is a recall on the 4.0 SOHC. The recall was sent out on the 27th of Nov. Call you local dealer or call the Ford hotline and have your VIN # ready. They will tell you if your vehicle is involved in the recall.
Good luck
Viper
  #5 (permalink)
Old 12-18-2000, 10:49 AM
jimshad is starting off with a positive reputation.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
